Bosch router self repair - Router Forums
post #1 of 4 (permalink) Old 07-24-2011, 09:10 PM Thread Starter
First Name: Dennis
Default Bosch router self repair
My small Bosch trimmer router has a habit of destroying the collet chuck more often than I'd like. Buying a replacement takes up to a couple weeks and costs about $11.00.
I found that by taking the four pieces of the chuck , taping them to a 1/4 " rod and slipping a #6,x 1/16 " "O" ring over it to hold it together and then putting it back in the tool and fixing the nut onto the shaft I could remove the rod and tape then use the tool again ! The "O" ring cost $.69.
Dennisefl is offline
post #2 of 4 (permalink) Old 07-24-2011, 09:57 PM
Hi Dennis,
that sounds like a band-aid fix to me, especially when you consider the speed that thing is moving.
have you been able to find out why the trimmer is destroying the chuck...I would give that a high priority.
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 07-25-2011, 10:29 AM Thread Starter
First Name: Dennis
I wrote a reply but can't find it. I also made a steel split cone to replace the delicate one Bosch supplies. Dennis
post #4 of 4 (permalink) Old 07-25-2011, 10:41 AM
Question Model
Which trimmer is that, the colt?
John Schaben
jschaben is offline
Rigid or Bosch Router? Marcus General Routing 13 12-06-2011 12:48 AM
No Lift Systems To Fit Bosch 1619EVS 3.25HP Router? DennisP General Routing 4 01-20-2010 05:23 PM
Bosch Router Table, what's a good router for it? friedrice2841 Starting Off 6 06-04-2009 07:44 AM
Bosch router table using pc895 router under routerron Table-mounted Routing 2 10-06-2006 11:50 AM
