Black & Decker 7625 Router - Router Forums
post #1 of 5 (permalink) Old 08-01-2011, 08:47 AM Thread Starter
First Name: Brian
Default Black & Decker 7625 Router
I picked up an old B&D 7625 router for a steal. It had a B&D router table and a Milescraft 1206 sign kit with it. I paid 10 dollars for the lot. My question is this, does anyone have any knowledge about this router? I know it was discontinued in the early 80's, but it seems to run well and it's built like a tank. If anyone has any feedback, I would greatly appreciate it. It is 1 1/4 hp 23,000 rpm.
scamp238 is offline
post #2 of 5 (permalink) Old 08-01-2011, 09:07 AM
Honored Member
First Name: pat
Good tool with plastic line cord (not rubber), 1/4 collet only, tho there was a short 3/8 accessory collet.
Machine is very well built, very good components. Rack & pinion up/down no grreater than average. Motor lock wing nut should be replaced with a lever lock.
Quillman is offline
post #3 of 5 (permalink) Old 08-01-2011, 12:48 PM Thread Starter
First Name: Brian
Thanks for the info. How would I replace the wing nut with a lever lock?
scamp238 is offline
post #4 of 5 (permalink) Old 11-07-2017, 02:50 PM
I need a parts breakdown for a Black and Decker 7625 router . Especially brushes , armature , rack , and Collette . Also have question . It throws a lot of sparks nothing is shorted to ground but on the armature I have continuity between all parts of commutator . Is that normal ? I would not think so . Also are there any parts still available for this unit ? Thanks . Vince
Vincent Ciaravella is offline
post #5 of 5 (permalink) Old 11-07-2017, 03:51 PM
Semipro's Avatar
First Name: John_*
Check and see if you can find it here
https://www.ereplacementparts.com/ro...715_18779.html
Semipro is offline
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
