DW 625 Problems. Help!!!! - Router Forums
post #1 of 7 (permalink) Old 08-10-2011, 04:37 PM Thread Starter
Country: Ireland
First Name: Niall
Exclamation DW 625 Problems. Help!!!!
Hi all.
I have a dewalt 625 which isn't going to well . the router is turning on but the variable speed doesn't seem to work and spins around a bit to easy . the router starts of fast from cold but then it starts to slow down and there's a strong smell of burning coming from inside the aluminium base (which also gets very hot and sparks fly from it ). Its also tripping out my 110 transformer. I took of the piece near the collet which is held on by three screws and behind this there was 2-3 shards of metal (possibly remains from a bearing????) The spindle won't spin freely by hand when knocked off. Is the armature burnt out or is it bearings and would it be complicated to fix providing i can get parts.
Thanks in advance for any help or advice you can offer
11IRE11 is offline
post #2 of 7 (permalink) Old 08-10-2011, 09:31 PM
Welcome to the router forum, Niall.
Thank you for joining us.
I hope some one can help...sounds like a new router to me......
Sydney, Australia
jw2170 is offline
post #3 of 7 (permalink) Old 08-10-2011, 10:36 PM
Originally Posted by 11IRE11 View Post
Hi all.
Hi Niel - Welcome to the forum
Sorry to hear about you problem. Unfortunately, from the description; burning smell, hot case, tripping transformer, metal fragments, the prognosis isn't to good. One of those things you will need to get it apart and see what it needs. May be best to just send it in to a service center for a post mortum.
John Schaben
jschaben is offline
post #4 of 7 (permalink) Old 08-14-2011, 05:25 PM
Hi all.
The main issues with self-disassembly are (1) Don't force the plastic switch in the top out with any degree of pressure because the plastic cylinder which extrudes from the switch and locks into the metal connecting rod down to the main on/off switch is very easily broken internally, and a new switch is quite expensive (2) You will need a small 2 prong gear puller to disconnect the armature, you mustn't use a hammer. See post http://www.routerforums.com/general-...lp-please.html.
The good news is that nearly all parts for that model are available to buy new, but they are expensive to buy individually. So if it more than just bearing failure, which is quite common due to the heat generated at the router bit, it may be cheaper to buy a second hand router just for the parts.
charlesb is offline
post #5 of 7 (permalink) Old 08-15-2011, 04:16 PM Thread Starter
Country: Ireland
First Name: Niall
Thanks Everyone,
Got in contact with my local tool supplier, Told him the symptoms and he reckons a new router is on the cards. he quoted me 200Ä for a new armature (not sure if this includes fitting) and a new 625 is 350Ä so i'm not to sure what to do. I can buy a new armature online for about 70Ä but not to sure if that's all that's wrong.
11IRE11 is offline
post #6 of 7 (permalink) Old 08-15-2011, 05:52 PM
First Name: Tim
Any way you can buy a reconditioned tool? I've had good luck with them. If you're handy you may want to see if it's a burnt out bearing. Only take it apart if you are certain you can do so without damaging anything.
TWBryan is offline
post #7 of 7 (permalink) Old 08-19-2011, 05:26 AM
There is an ad on ebay for a "dewalt dw625ek armature repair kit 240 volt, this repair kit is brand new out it will fit all dewalt dw625ek elu mof177e routers....avaliable in 240 volt and 110 volt." for only £49.99 + postage, but bearings are extra.
charlesb is offline
First table style routing gave infeed and outfeed problems loninappleton Table-mounted Routing 3 09-20-2009 05:48 PM
Problems, problems, problems nikki1492 General Routing 7 07-21-2009 08:50 AM
Porter router 7518 problems (URGENT!!!!!!) marc.brunet.gagne General Routing 2 04-30-2008 08:52 PM
Problems with cabinet door rails... Coon Table-mounted Routing 11 04-17-2008 11:15 AM
Dewalt 625 issues and questions Greg_R General Routing 9 12-11-2007 04:16 PM
