My flush trimming split my workpiece - Router Forums
post #1 of 11 (permalink) Old 08-11-2011, 06:37 AM Thread Starter
ScoFF's Avatar
First Name: Bob
Default My flush trimming split my workpiece
I had a project recently where I tried to flush trim a piece of red oak to match an attached template. I roughly trimmed the 3 foot board lengthwise about 1/4 “ from my pencil line and attached the straight edge template and tried to straighten the edge of the board, the template was on top, the flush trim bearing was also on the top of my table mounted setup (so I guess the bearing would have been at the bottom of the actual bit). I thought this would be a pretty basic exercise.
About ˝ way through it snagged the grain and split it inwards beyond my pencil line. I had to scrap it and do it again. I’m not an expert on grain direction but I guess I should have flipped the work piece over and came at it the opposite direction?
What if I couldn’t flip it over, say I was trimming a large table edge (non-table setup) and I had only one choice to go. How do I overcome this?
ScoFF is offline
post #2 of 11 (permalink) Old 08-11-2011, 06:51 AM
Hi Bob,
I am guessing the template was not flat and allowed the bearing to rise above the template.
Even with a 'snag', the bearing would not have allowed the bit any closer to the template/work piece.
Unless the bearing was not riding along the template to begin and it only moved in to the edge of the template?
Sydney, Australia
jw2170 is offline
post #3 of 11 (permalink) Old 08-11-2011, 08:40 AM
kp91's Avatar
First Name: Doug
red oak will chip out like that, and always at the worst time. you can try a couple of different things to help. You're right on track that you should try to feed the stock so that you're running 'downhill' with the grain. (just make sure you always feed on the correct side of the bit, don't climb cut) If you can't do that, you can make a few relief cuts with the router every few inches along your template so that if it does snag it doesn't pull out a big long piece.
Sorry about your project.... hope it doesn't happen again soon.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 11 (permalink) Old 08-11-2011, 08:40 AM Thread Starter
ScoFF's Avatar
First Name: Bob
The bearing position was fine, the bit just grabbed the grain and ripped it down the direction it was flowing. How do you prevent the tearing down the grain direction? It litterally cracked apart.
ScoFF is offline
post #5 of 11 (permalink) Old 08-11-2011, 08:57 AM
Try using the bit below it will help with rip outs..
Spiral Flush Trim Router Bit
Great for use where chip-out is a concern with plywood, melamine or other laminate surfaces.
MLCS solid carbide router bits
Name:	carb trim bit.jpg
post #6 of 11 (permalink) Old 08-11-2011, 09:15 AM
Honored Member
First Name: pat
Use a plunger and collars; take the cut in stages.
There is always a depth of cut, albeit likely shallow, that will not tearout or split stock.
It may be a 1/32, it may be an 1/8th, who knows?
Not withstanding stage plunge cutting is safe, perhaps slow, but offers the greatest number of choices in cutters and your best chance at a quality result.
Quillman is offline
post #7 of 11 (permalink) Old 08-11-2011, 09:53 AM
RJM60's Avatar
First Name: Robert
I don't see why you couldn't do a climb cut if the grain warrants it. Combined with several shallow passes, it's not dangerous if you know what you're doing.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #8 of 11 (permalink) Old 08-11-2011, 10:37 AM
Bob, the best method for eliminating problems like you had is to make light scoring cuts on the wood. To do this simply push the wood into the bit and pull the wood back. Repeat this every inch or so then make your regular pass.
post #9 of 11 (permalink) Old 08-11-2011, 11:23 AM
First Name: john
I agree that a CAREFUL climb cut will help. By using a climb cut the bit pushes the wood fibers toward the board and should not tear out even rd oak. You might try using a larger diameter bit and several light passes if you are not comfortable with climb cutting. The objective is to get the angle between the cutting edge and the cut line as low as possible. Using a 1/2" dia bit and a 1/4" cut depth would put the cutting angle at nearly 90 degrees for the fibers at the rough cut surface.
Red oak is made up of a thousand potential splits hidden in pretty grain. The late wood is very poorly attached to the early wood.
johnwmartin50 is offline
post #10 of 11 (permalink) Old 08-11-2011, 03:27 PM
Hi
Just to add to Mike's post
This works well for trim bits also
Router Workshop: Tipb2
http://www.routerworkshop.com/Tipb4.html
Router Workshop: Router Tip Archive
http://www.routerworkshop.net/1726/d...e-pass-or-not/
http://www.routerworkshop.net/1694/a...picture-frame/
flush trimming deeprabbet Table-mounted Routing 2 01-31-2011 08:19 PM
Vertical Flush Trimming Base Plates taxque Portable Routing 10 06-27-2010 02:31 PM
flush trimming 3/4" and 1" mdf z399y General Routing 8 05-09-2010 01:09 PM
Good bit for flush trimming thick stock? jimgo Router Bits - Types and Usage 12 03-24-2010 10:30 AM
Router Table Flush Trimming Problems jimcrockett Table-mounted Routing 12 03-23-2008 08:06 PM
