Best Routing Bit for slots - Router Forums
post #1 of 5 (permalink) Old 08-11-2011, 08:21 PM Thread Starter
Default Best Routing Bit for slots
Hi
Only new to using my Dremil and I need to cut some 25mm wide x 40mm long x 5mm deep slots in some Marine Ply. What would be the best Dremel Router bit to use.
Thanks Stephen
animal is offline
post #2 of 5 (permalink) Old 08-11-2011, 09:34 PM
Welcome to the router forum, Stephen.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #3 of 5 (permalink) Old 08-11-2011, 09:53 PM
Originally Posted by animal View Post
Hi
Thanks Stephen
HI - Welcome to the forum
I haven't got a dremel, at least not the dremel rotory tool. I believe they are limited to 1/8" shanks though. That would be a lot of passes, even though the slots are relatively small. Maybe just cut the outline with a straight bit to define the sides and remove the bulk of the waste with a chisel. Marine ply is pretty tough stuff, lotsa resins. I think if you try to do the whole thing with dremel bits you will need to buy them by the case. If you have a mate with a router, a 10 or 12 mm bit would make short work of that.
Good Luck
John Schaben
jschaben is offline
post #4 of 5 (permalink) Old 08-11-2011, 10:23 PM
Send off for the bit set below or I'm sure you can find the Steelex set in AU.
Amazon.com: Steelex D2721 1/8-Inch Mini Shank Router Bit Set, 10-Piece: Home Improvement
Hi
Thanks Stephen
post #5 of 5 (permalink) Old 08-11-2011, 11:28 PM
Hmmm, didn't know that existed, Trust BJ
Anyway, it says you need a router base to go with it so you can get this one while your at it
Amazon.com: Milescraft 1000 Plunger turns your Rotary Tool into a plunge router: Home Improvement
Cost wise, you may be getting close to a proper router though.
John Schaben
jschaben is offline
Sears router bit description gary smyth Router Bits - Types and Usage 4 07-01-2011 05:15 PM
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 03:17 PM
Router Bit Accuracy Mike Wingate Router Bits - Types and Usage 8 06-24-2009 12:38 PM
T&G routing bit graydocs Table-mounted Routing 12 07-27-2006 10:04 AM
RouterForums Amateur Night Rabbet bit Tables reible Router Bits - Types and Usage 1 10-10-2004 09:03 PM
