metric/imperial router collet+sleeve - Router Forums
post #1 of 8 (permalink) Old 08-12-2011, 04:53 AM Thread Starter
Country: Malta
First Name: Joseph
Default metric/imperial router collet+sleeve
I have this ryobiERT1050 router which has a 12mm collet and came with 8mm and 6 mm sleeves. Now you know that most bits are either 1/4" or 1/2" hence my problem comes here. I can use the bits which came with the router but surely not any of the most which are available and sold separtely. I will try and get an imperial measurement collet and sleeves. So just watch out befor buying any router and check the collet/sleeves so as not to end up with my problem!
Mosti is offline
post #2 of 8 (permalink) Old 08-12-2011, 08:03 AM
Hi Joseph,
I understand from other posts that those sizes are very common in Europe.
I would have thought the bits in those sizes would also be available.
Sydney, Australia
jw2170 is offline
post #3 of 8 (permalink) Old 08-12-2011, 12:45 PM Thread Starter
Country: Malta
First Name: Joseph
Originally Posted by jw2170 View Post
Hi Joseph,
That's what I thought but the selection is not as good as with the 1/4 and the 1/2"
Ihope to find an adequate collet.
Cheers.
Mosti is offline
post #4 of 8 (permalink) Old 08-12-2011, 04:10 PM
Phil P's Avatar
First Name: Phil
Joseph
Try looking in either the UK or USA for these items. On ly the UK and Ireland use 1/4in and 1/2in collets as a norm in Europe. Everyone else uses metric
Regards
Phil
Phil P is offline
post #5 of 8 (permalink) Old 06-03-2012, 12:00 PM
Country: France
First Name: Geoffrey
Default Metric / imperial
I too am looking for this size sleeve - 12mm to 1/4" . I have moved to France from the USA and brought along my 1/4" router bits. I've purchased a 12mm router with 6 and 8mm sleeve adapters. But, I'd like to continue using my collection of 1/4" shanks.
If anyone has a clue where to find this METRIC TO IMPERIAL sleeve adapter on the Internet, please post here. I have not had any luck finding true 12mm to 1/4".
Thanks in advance...
contactzero is offline
post #6 of 8 (permalink) Old 06-03-2012, 12:57 PM
Hi
You can make your own, just drill one " sleeve adapter " out to 1/4" ID
post #7 of 8 (permalink) Old 06-07-2012, 06:01 PM
Phil P's Avatar
First Name: Phil
Hi Geoffrey
Depending on which router you have many manufacturers do have 1/4 and 1/2in collets for their routers - it's just that you may need to go mail order from the UK to get one. A properly sized collet is a far safer option that a conversion bushing and the bit is far less likely to drop out and ruin the cut, either. Post the router make and model and someone may be able to help you
Regards
Phil
Phil P is offline
post #8 of 8 (permalink) Old 06-24-2012, 11:23 PM
First Name: gary
CMT prints 2 catalogs. One intended for worldwide customers shows everything they make, metric and Imperial sizes. In North America we usually see only the smaller catalog. If you want a collet that will allow to adapt Imperial shank bits to your Metric router, Lee Valley of Canada sells them for less than $10.
garycurtis is offline
replacing collet on Bosch router SanderW General Routing 15 03-31-2019 02:58 PM
Sears router collet question barking spider General Routing 2 01-08-2011 09:52 PM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Router collet nut dj92 General Routing 11 11-09-2009 02:03 PM
