what do you use to clean bits? - Router Forums
 3Likes
post #1 of 27 (permalink) Old 08-14-2011, 08:06 AM Thread Starter
allthunbs's Avatar
First Name: Ron
Default what do you use to clean bits?
As part of the discussion on helix planer heads at:
http://www.routerforums.com/tools-wo...tml#post245634
one of the requirements of Helix planer heads is that they be perfectly clean. To clean my router bits I'm using a concoction from Rockler called Pitch and Resin Remover. At $10.59 US plus shipping and taxes, this can quickly become an expensive situation.
Cleaning pitch and resin off of tools is not new and must be a problem since the beginning of cutting tools.
What do you use?
Do you have a concoction that your grandfather taught you and you're using even today?
Do you soak your tools or do you "spray" or do you brush?
Along those lines, do you clean your collet chucks the same way?
Are there alternatives to cleaning, i.e. do you pre-treat your bits.
Do you have a separate concoction for saw blades or "does one size fit all?"
Your comments are appreciated.
Allthunbs
allthunbs is offline
post #2 of 27 (permalink) Old 08-14-2011, 09:47 AM
What do you use?
Hi Ron - I essentially use the same stuff, Rockler Pitch and Resin Remover. However, I buy the concentrate. $14/qt but mixes with water at 4:1 giving a 1 gallon (US) yield. The mix is also reusable so I use it for the soak. Most of it is in a large, lidded pan to handle saw blades and the rest in a pint canning jar to handle the router bits. Been using this batch for a little over a year now. I also have a squirt bottle of CMT cleaner for quickie touch ups.
That said, I have been cleaning router bits after every use. Just a wipe down with a towel moistened with whatever household cleaner I happen to have, 409, Fantastic, Mean Green.... etc. If there is anything that won't come off there, I spray it with a bit of the CMT cleaner and leave it set for a few minutes and wipe it off. I also use a brass brush at this time. So far I haven't had to go to any greater lengths.
Saw blades get cleaned and waxed whenever they come off the saw for any reason. Usually a spritz with the CMT cleaner and a 15 minute wait time is sufficient. When I first started on the Rockler cleaner, an overnite soak cleaned up everything. Remove router bearings before they go in the soup.
Sorry, I haven't got a planer so have no idea how to deal with those.
John Schaben
jschaben is offline
post #3 of 27 (permalink) Old 08-14-2011, 11:48 AM
Gene Howe's Avatar
First Name: Gene
Like John, I use 409 or Simple Green on saw blades and router bits.
Also, definitely heed John's caution to be careful with caustic stuff and router bit bearings. Soaking will degrease them and make them useless/dangerous.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #4 of 27 (permalink) Old 08-14-2011, 11:48 AM
Phil P's Avatar
First Name: Phil
Hi Ron
I've used an industrial compound called "Aqueous Solution" for years. It comes in 1 gallon/5 litre bottles of concentrate and is diluted for use. It is a citrus-based solution which can safely be tipped down the drain after use (according to the COSHH notes accompanying it), unlike the turps, meths or paraffin concotions used by our grandfathers. It also works quicker, IMHO. A near match for it would be the CMT Orange bit cleaner.
I tend to spritz on (to router cutters) and then get to work with an old toothbrush and tooth picks; heavier deposits require a soaking. Like John I always remove bearings before cleaning - they get a separate treatment of wiping the outsides with a cloth dampened with white spirits (to remove contact adhesive which won't rub off with a coarse cloth) followed by a quick spritz of WD-40. Collets and collet nuts get the same treatment as cutters, albeit using a brass wire brush for the insides. The router cone gets cleaned with a soft cloth and neat cleaner from time to time. Saw blades are left to soak in a tray of solution overnight before applying the brush/toothpicks; planer blades get the same treatment (it's simpler to take stuff off at the end of a session, leave it in soak and then clean, dry, oil and refit the following day). In all cases except for bearings I use BoeShield protective oil afterwards if the item is being stored
I'm sorry to say that I don't think there's any way to pre-treat bits to make them stay clean. By its nature wood contains sticky resins, as do MDF and particle board (melamine, chipboard, etc). Teflon-coated bits do stay cleaner - until the first time they are sharpened when half of the coating always seems to disappear.
I don't clean my tools every time they are used, instead I look for signs of a build-up and treat them then - to clean each tool each and every time it is used would be a nightmare in both time and cost terms
Regards
Phil
Phil P is offline
post #5 of 27 (permalink) Old 08-14-2011, 12:37 PM
post #6 of 27 (permalink) Old 08-15-2011, 12:15 PM
derek willis's Avatar
First Name: Derek
Cellulose thinners!!!!!!!!!!!!!!
Derek
derek willis is offline
post #7 of 27 (permalink) Old 08-15-2011, 12:22 PM
bobbotron's Avatar
First Name: Rob
I usually just use mineral spirits, it gets them pretty clean, and it's not too toxic, as far as cleaners go...
bobbotron is offline
post #8 of 27 (permalink) Old 08-15-2011, 12:26 PM
http://www.birdbrand.co.uk/msds/Cell...20Thinners.pdf
post #9 of 27 (permalink) Old 08-15-2011, 03:24 PM
N'awlins77's Avatar
First Name: Lee
WD-40 or equivalent, hasn't failed me yet!
N'awlins77 is offline
post #10 of 27 (permalink) Old 08-15-2011, 03:33 PM
Phil P's Avatar
First Name: Phil
Cellulose thinners? Mineral spirits (white spirits?)? Really good for the environment, those are! Not to mention highly flamable.
Regards
Phil
Phil P is offline
Getting started with router bits Mike Router Bits - Types and Usage 26 02-22-2015 02:23 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
Best way to clean shipping 'grease' off new router bits? Gator95 General Routing 4 03-01-2008 07:59 PM
