porter cable dove tail jig 5008 - Router Forums
post #1 of 5 (permalink) Old 08-20-2011, 03:00 PM Thread Starter
First Name: jeff
Default porter cable dove tail jig 5008
I bought on of these and i am not sure how to use it,My question is what size guide should i use and what size bit?I have the manual but it doesn't say.I know how to use it generally i just need the specifics.
jsjcarp is offline
post #2 of 5 (permalink) Old 08-20-2011, 07:52 PM
Hi Jeff.
Mike posted a copy of the manual. On page 6 it says to use #42027 Template guide & # 43640 1/2" Dovetail Bit. These #'s are Porter Cable part numbers. Page 13 of the manual under accessories gives you all the part numbers you need for 1/2" & 1/4" Dovetails. Just google the Porter Cable numbers to find a description.
The #42027 Template Guide is a 7/16" guide:
  • Distance past base of 5/32-inch
  • 11/32-inch I.D.
  • 7/16-inch O.D.
The #43640 7 Dovetail Bit, HSS, High Speed Steel, 1/2" Cut Width, 1/4" Shank
You can use another brand that fits these descriptions.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 5 (permalink) Old 08-21-2011, 08:19 AM
Regardles of what they say in the manual I do not care for a 7 dovetail bit. I would use a 1/2" 14 dovetail bit as it makes a much stronger joint.
post #4 of 5 (permalink) Old 08-21-2011, 09:10 AM
Hi Mike
But the 14 deg. dovetail bit is for BLIND dovetails only the norm.
Plus the 7 deg.dovetail bit will do both types in fact it is a bit stronger because you don't have the ears like with the 14 deg.bit ,that like to snap off very easy..I use the 7 deg.bit on MDF/Plywood and you know that stuff, it will snap off if you you look at it the wrong way.
post #5 of 5 (permalink) Old 08-22-2011, 03:16 AM
You raise a valid point BJ. I almost never work with MDF and wouldn't cut dovetails on plywood. About the only time I do use a dovetail bit is for sliding dovetails and the 14 bit works much better for this. If you are working with solid wood it also makes for a more eye catching joint.
porter cable 4216 jig Da Mrs. Jigs and Fixtures 8 12-14-2011 10:19 AM
porter cable dovetail jig dpb1026 Jigs and Fixtures 3 08-15-2011 07:25 AM
How do you get the Rockler dove tail jig to work with a Porter Cable router? 1jwthompson Guide Bushings and Templates 3 01-03-2009 01:43 AM
