Craftsman 3 Hole Pattern - Router Forums
post #1 of 9 (permalink) Old 08-25-2011, 03:07 PM Thread Starter
First Name: Ron
Default Craftsman 3 Hole Pattern
I have a Craftsman Bis-Kit cutter attachment that fits the Old Craftsman three hole pattern. I have two DeWalt routers that have only the four hole pattern. Anyone know what fixed base router brands, besides Craftsman, that will fit the three hole pattern on the jig?
I need to get a used one that will be used only on the biskit fixture. Thanks for any help.
rweerstra is offline
post #2 of 9 (permalink) Old 08-25-2011, 04:19 PM
Ron, it is easy to drill and counter sink the holes so you can use your DeWalt. Remove the sub base plate from your router and use it as a template to mark the hole locations on the Bis-Kit adapter.
post #3 of 9 (permalink) Old 08-26-2011, 10:24 AM Thread Starter
First Name: Ron
Default Thanks
Yes Mike, I have done that on other mountings but I was planning to get a dedicated router for the Biskit jig. Since it doesn't have to be much of a router, I thought I might pick up a inexpensive, used, Craftsman or some other Brand that would fit the pattern and leave it mounted on the jig. I have seen a few Craftsman on Craig's list but they are not local or have too many accessories to be sold cheap.
Thanks again.
post #4 of 9 (permalink) Old 08-26-2011, 06:59 PM
Ron, this is a reason to visit a Sears store. Odd's are good you will find one of the new Craftsman Combo kit routers that is missing parts; these sell for under $40 and would be perfect for the job.
post #5 of 9 (permalink) Old 08-27-2011, 12:25 PM Thread Starter
First Name: Ron
Sounds like a good plan. Craigs list has not been too helpful and the nearest Sears store is 40 miles away but a good plan non-the-less.
post #6 of 9 (permalink) Old 08-27-2011, 12:40 PM
How about buying just the fixed base & mount that & leave it attached. When you want to use just slide out the motor from the other router & slide it into the other base when you want to use it.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #7 of 9 (permalink) Old 08-27-2011, 01:47 PM
Ron, I know some people are sensitive about giving out their location on the internet. If you tell us what state you are in we may be able to assist you better in finding a deal. For example I tell people I am in Detroit, MI. I actually live in a suburb but it is close enough to let others know my area when deals are available. There could be another forum member in your area who has an old Craftsman they want to part with.
post #8 of 9 (permalink) Old 08-28-2011, 03:20 PM Thread Starter
First Name: Ron
Good idea. I am located in Holland, Michigan, about 500 yards from the big, beautiful, unsalted lake.
post #9 of 9 (permalink) Old 08-28-2011, 05:43 PM
Hi Ron
I had one ,of the Craftsman fixtures like I said I had one, I got it out of the shop like most of the junk fixtures I had by Craftsman and I am a fan of many of the Sears jigs,,,you can do it on the router table so easy and quick without all of the pain...see link below..
Biscuit kits and Glue Spreader
Craftsman really? brownsfn2 General Routing 25 07-18-2011 12:58 PM
Hole Pattern on Router Base Avery Table-mounted Routing 6 07-22-2010 12:04 PM
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 10:29 AM
craftsmen router? rhe8542 Starting Off 21 04-20-2009 10:51 PM
Which hole pattern should I get (plate for a Bosch 1617)? Nickbee Table-mounted Routing 1 11-23-2007 06:49 PM
