Reassembly - Router Forums
post #1 of 4 (permalink) Old 09-02-2011, 01:32 PM Thread Starter
First Name: Maurice
Default Reassembly
O dear, O dear! I am so dissappointed that my Elu177e is now seriously OVERHEATING the collet end of the spindle after running for less than a minute.
I can only presume it's due to rotational slippage between the inner race of the bearing and the spindle which can't be 'interference' fit so housing/handles can be tapped off.
I've fully tightened the 'lock ring' which must be for the purpose of solidifying both together.
FULL tightness of course has pulled the spindle (armature shaft) a couple of mm towards the collet so the saucer washers under the other (tail end) bearing would be now fully compressed - is this too tight?
With the circular cover-plate for the lock ring removed, I can see the outer race rotating very slowly in it's housing. This cover has a projecting rib - the diameter of the outer race, which may (?) clamp it stationery when screwed back in place.
Fact is, though a one time Instrument Technician, without detailed reassembly instructions I'm, frankly, buggered!
Any help to dig me out of this would be much appreciated
shedhappy is offline
post #2 of 4 (permalink) Old 09-02-2011, 08:26 PM
dutchman 46's Avatar
First Name: Howard
Sorry Maurice! I was searching for answers, and this came up- ELU MOF 177E ROUTER | eBay I hope that this may help. Check out the router manuals in the forum GO list. They may have a manual for You. There will be more replies Tomorrow, or for sure Monday!
John 3:16
dutchman 46 is offline
post #3 of 4 (permalink) Old 09-02-2011, 08:48 PM
First Name: Howard
elso u. elu,baring - Keyword Stats Check this out! Is there any thing here that may help?
John 3:16
post #4 of 4 (permalink) Old 09-06-2011, 12:42 PM Thread Starter
First Name: Maurice
Thanks for that -
but on that site it will take me a while figuring out how to actually 'find' the item I just clicked to view!
