cross grain routing of plywood - Router Forums
post #1 of 5 (permalink) Old 09-03-2011, 10:33 AM Thread Starter
Default cross grain routing of plywood
I'm seeking the best technique to rout a 3/8 rabbet in 3/4 inch 4x8 birch ply, cross grain to lay boards end to end. Test runs consistently splinter. I use a Bosch 1613 EVS plunge router.
Thanks for any tips
bonzo is offline
post #2 of 5 (permalink) Old 09-04-2011, 05:31 AM
CharleyL's Avatar
First Name: Charley
A down spiral carbide bit will make a big difference. It needs to be very sharp for best results. Sometimes a layer of painters tape over the area to be cut will help to hold down the edge grain as it's cut. Slightly dampening the surface veneer in the area to be cut also helps. When all else fails, scoring the cut lines down through the veneer with a very sharp knife before removing any material with the router will help. One or a combination of these should solve your problem. I usually try them in the order posted until I get the results that I need.
Charley
CharleyL is offline
post #3 of 5 (permalink) Old 09-04-2011, 08:10 AM
kp91's Avatar
First Name: Doug
Bonzo,
A shallow first pass helps sometimes, and I have to second the masking tape suggestion
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 5 (permalink) Old 09-04-2011, 09:26 AM
Hi
Here's a router bit made just that type of job..
Compression Up/Down Spiral Router Bit
MLCS solid carbide router bits
post #5 of 5 (permalink) Old 09-04-2011, 05:34 PM Thread Starter
Many thanks Charley - will run some test strip. Sounds good.
bonzo is offline
Cross grain Lakelad General Routing 7 03-22-2011 07:52 PM
Routing Baltic Birch Plywood ET1 General Routing 3 07-05-2009 01:19 AM
Routing Baltic birch plywood (noob warning) dan_house General Routing 5 02-19-2009 05:30 PM
Routing plywood gerwally Starting Off 1 11-19-2008 01:12 AM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
