router won't start - Router Forums
post #1 of 4 (permalink) Old 09-03-2011, 12:30 PM Thread Starter
Default router won't start
I have a Craftsman 2hp model # 315 2450000 that I can't start. Worked great up until now. Won't start and the bit keeps locking even when unlocked. Any suggestions?
MikeeBoy is offline
post #2 of 4 (permalink) Old 09-03-2011, 01:50 PM
papawd's Avatar
First Name: warren
Welcome, look inside sounds like it is freezing up, find a maual or pdf file on that model and take apart bearings prolly full of sawdust need changing ...GOOD LUCK
papawd is offline
post #3 of 4 (permalink) Old 09-03-2011, 04:57 PM
BigJimAK's Avatar
Mikee,
Does the router use one wrench to change bits or two? Single-wrench collets usually have a button you push to lock the shaft. Some routers have a switch associated with this button that prevents startup while the button is pished. Perhaps the collet lock switch is gummed up?
Jim
BigJimAK is offline
post #4 of 4 (permalink) Old 09-04-2011, 01:35 PM
dutchman 46's Avatar
First Name: Howard
Check the shaft lock! When You open, or install, remove a bit, the lock is locked with a slide. check to see if it is on!
John 3:16
dutchman 46 is offline
Soft Start Router wes0711 General Routing 20 08-02-2010 04:33 PM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
