Router to mount in drill press - Router Forums
post #1 of 6 (permalink) Old 09-06-2011, 05:19 PM Thread Starter
First Name: Gregg
Default Router to mount in drill press
I bought a (fitment?) for a portable electric drill which basically converts is into a radial arm drill, and thus a radial arm saw/sander/sabre saw/hedge cutter or whatever fits onto the electric drill.
I'm thinking it would be *brilliant* to attach a small router to this thing - and I know there are routers which have a 43mm (euro?) collar - such as the trend T4.
I'm struggling to find a list of other routers which may be suitable for this application - any recommendations? up to say 800w.
I suppose I could just chuck a router bit in the drill, but...
bigegg is offline
post #2 of 6 (permalink) Old 09-06-2011, 05:47 PM
I've considered fitting a router to a radial arm drill press frame. No reason for it not to work. I have tried router bits in the drill press. They work but not well. Too slow and a lot of vibration.
post #3 of 6 (permalink) Old 09-07-2011, 02:34 AM
Welcome to the forum, Gregg.
I agree with Charles - router bits are designed to run at a much higher speed (8,000- 25,000 RPM)
Sydney, Australia
jw2170 is offline
post #4 of 6 (permalink) Old 09-07-2011, 10:10 AM Thread Starter
First Name: Gregg
Yes - that's been my experience as well, I'm not keen on router bits in the drill press.
I've run them in a mill/drill which elimated vibration, but still ran too slow.
This thing I've bought is a very heavy duty drill stand which has as much adjustment possibilities as a radial arm saw, plus an (admittedly lightweight but still rigid) adjustable table which tilts, swivelsand raises.
It's obviously commercial, but no maker's name, and takes a standard black and decker type electric drill.
I want to use a small router in it - and I'm wondering is there a router which will fit straight into a 43mm drill press collar?
bigegg is offline
post #5 of 6 (permalink) Old 09-07-2011, 05:34 PM
Phil P's Avatar
First Name: Phil
Hi Greg
Look for Kress on the net. They do motors which are often sold for hobby CNC use. Other manufacturers who make or made 43mm collar routers include (from memory) Bosch (POF500/POF600), Metabo, Felisatti, Freud, AEG, Black & Decker, etc although the format is limited to 1/4in chucks and 600 watts in most cases (so you may need to look for second hand as most manufacturers have discontinued their smallest routers)
BTW chucking a router bit in a drill press will result in (i) damage to the router shank and (ii) disappointment. A 3,000 rpm drill press can't produce as good a finish as a 24,000 rpm router
Regards
Phil
Phil P is offline
post #6 of 6 (permalink) Old 09-08-2011, 06:15 AM Thread Starter
First Name: Gregg
Thanks for that -
I like the look of the Kress stuff, and since a CNC router is on my "to do" list, it can serve double duty.
bigegg is offline
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
Drill Press -Sam- Tools and Woodworking 18 07-24-2005 09:03 PM
