How to Make a Raised Panel Door - Router Forums
post #1 of 3 (permalink) Old 09-06-2011, 08:07 PM Thread Starter
Default How to Make a Raised Panel Door
In video number 109, Bob Rosendahl shows us how to make something that sounds complicated, but is really easy—panel doors. These can be used for cupboards, a feature wall or even cabinets. Let’s get started.
Setup
To make a raised panel door, you will need to have a bit that can make three cuts in one—the cope cut and bead cut. It is a 3-inch bit, which is a bit wider than the normal size bit, but this is fine. Go ahead and put in your bit, then place your base plate back in the table. The base plate should have two holes on either side of the router bit hole so that your fence can line up perfectly, which will automatically set up your distance. Be sure to clamp it down so that it is completely secure. Set your bit height to be at the same level of your materials.
Your door panel kit should include three panels, two long outside pieces (stiles), and run up and down the full length, three rails for the top, bottom and center, and a mullion, which are molded on both sides and make up the space between the two panels. When cut, these should make up the entire panel door. Decide which sides should be your face side and mark them with an “x” in pencil.
Step One
Using your push stick, make a cope cut on each end of the rail pieces and the mullion piece, face side down. Without changing the bit, lower the bit to the bead cut bit and make a bead cut, using the push piece again, on the stiles pieces, as well as the top and bottom rail pieces, with a bead cut on one side only; on the mullion and center rail piece, make a bead cut on both sides. Always remember to cut with the grain so that you do not tear out the wood. Each cut piece should fit together nicely when cut. Set aside and it is now time to work on the panels.
Step Two
Change out the bit to the panel bit and adjust bit for correct height. Take your panel pieces and cut around all the edges, starting on the bottom with the grain, doing the side, then top and other side.
Step Three
Now you get to put a puzzle together! Put all edge pieces together on the panel pieces, with the stiles on outside, the mullion piece in the middle, the center rail piece between the other two panels and the bottom rail piece. Glue together and enjoy!
Click here to join the Router Workshop!!
learnexperience is offline
post #2 of 3 (permalink) Old 09-06-2011, 08:17 PM
What are you describing? Cabinet doors or passenger doors? Usually it takes more than one bit. Cabinets & pass doors use different size materials & different types of bits. Your cope & stick might be one combination bit or a matched set. The panel bit would be a different bit as the diameters are larger.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 3 (permalink) Old 09-06-2011, 08:39 PM
Hi
I was thinking the same as you James, the bit Bob used was a combination bit the bigger bit was 2 1/2" diam.. both ,they don't sale them any more nor the jig setup for them..it was a neat jig setp but no sales I guessing...
The combination bit can still be had from Grizzy but it's real PITA to use..and very hard to get setup right.. I have one in the router drawer...but not the jig for it..the only member that know about that has one is Deb ,,that I know about..
Bit ,, below,, but with bearing on it..the OP one didn't have a bearing on it.. I have it both ways..
C1689 One pc. Stile and Rail Set - Quarter Round
Raised Panel End Grain Question. AlanSweet The Finishing Touch 6 05-17-2010 08:32 PM
Wainscoting Raised Panel jerry45 New Member Introductions 3 08-11-2009 08:56 PM
research for raised panel doors presumed_druid Table-mounted Routing 4 01-13-2006 10:47 PM
Welcome to "Show N' Tell" Mark Show N' Tell 0 08-17-2005 04:55 PM
Cedar raised panel doors fred m deolick General Routing 15 10-07-2004 11:02 PM
