Muscle chuck - Router Forums
post #1 of 5 (permalink) Old 09-06-2011, 09:56 PM Thread Starter
First Name: JAMES
Default Muscle chuck
I recently bought the above device through Wood Rat. It replaces your router's collet with ability to change bits by using there hex tool (resembles an allen wrench). It accomodates 1/2" and 1/4" bits with the addition of a sleeve. The device works fine with 1/2" bits but will not tighten 1/4" bits. Has anybody else had any experience with this device?
EQUINOX400 is offline
post #2 of 5 (permalink) Old 09-06-2011, 10:05 PM
Hi James
If it's the same as below I had one and had the same error now it's my tool box with other tools I don't use any more// >>>
Woodworking Accessories - Eliminator Quick Chuck
http://www.ebay.com/itm/4-pc-Collet-...item20bb505d3f
post #3 of 5 (permalink) Old 09-07-2011, 10:00 AM
CharleyL's Avatar
First Name: Charley
Are you sure it is supposed to work on 1/4 inch bits? Being that Wood Rat is an English company, maybe it is for 8 mm bits which are slightly larger in diameter than 1/4 inch.
I don't have a Wood Rat, so I'm just guessing, but the Europeans don't use 1/4 inch bits unless they need a special profile that is only available from the US, and then they have to buy a special adapter to use it. Reading the Wood Rat manual may help.
Charley
CharleyL is offline
post #4 of 5 (permalink) Old 09-07-2011, 03:22 PM
Midlife's Avatar
Country: Czech Republic
First Name: Anthony
Send a message via Skype™ to Midlife
i think (not to often) 6mm bits are to small for a 1/4inch collett ie 6.35mm ?
Midlife is offline
post #5 of 5 (permalink) Old 09-07-2011, 05:26 PM
Phil P's Avatar
First Name: Phil
Hi Charley
Us Brits use mainly 1/4in and 1/2in shanks with some 8mm mixed in for good measure (a bit like yous guys if one includes Leigh cutters). Sur le Continent the don't recognise Imperial (sic) measure, so they are left with the Code Napoleon shank sizes of 6mm, 8mm and 12mm.......
BTW 6mm and 1/4in (6.35mm) are not interchangeable, neither are 12mm and 1/2in (12.7mm)
Regards
Phil
Phil P is offline
Bits stick in chuck StuckChuck General Routing 12 12-29-2010 04:09 PM
What are my chuck options? AlmostHandy Woodturning and Lathes 6 08-12-2010 12:37 PM
Vacuum Chuck BernieW Woodturning and Lathes 6 02-21-2010 05:21 PM
problems with chuck basser General Routing 1 05-25-2009 07:06 PM
Hitachi M12V Collet chuck loose idkjs General Routing 1 11-29-2005 09:36 AM
