Edge routing mitered frame. - Router Forums
post #1 of 10 (permalink) Old 09-10-2011, 09:42 PM Thread Starter
RJK
Default Edge routing mitered frame.
I am making a 4 inch frame that will have mitered corners. Is it better to edge route (roman ogee) the pieces before assembly and then assemble, or assemble the frame first and edge route the assembled piece.
Also, is it better to do this on my router table, or should it be done hand-held.
Thanks.
RJK is offline
post #2 of 10 (permalink) Old 09-10-2011, 09:59 PM
Hi RJK
I would suggest doing it on the router table and then cut the miter ends.
Here's quick and easy way to get all 4 parts to the frame.
http://www.routerforums.com/table-mo...nel-doors.html
Thanks.
post #3 of 10 (permalink) Old 09-11-2011, 12:45 PM
derek willis's Avatar
First Name: Derek
Always shape your timber, then cut to size or mitre, that way you are safe and get a better finish.
Derek
derek willis is offline
post #4 of 10 (permalink) Old 09-11-2011, 04:07 PM Thread Starter
RJK
Thanks Derek, I appreciate the feedback. I'll edge them first, then cut/mitre, and then assemble the piece.
RJK is offline
post #5 of 10 (permalink) Old 09-11-2011, 08:21 PM
CharleyL's Avatar
First Name: Charley
It's normally best to shape the wood before cutting/mitering, but sometimes you may want the inside of a frame or hole to have the molded pattern rounded at the corners. Using a bottom bearing router bit and going around the inside edges of the frame will cut the molded pattern, but round the corners by the radius of the bearing that is on the bit. Sometimes this in undesirable while other times this is a desired pattern.
Charley
CharleyL is online now
post #6 of 10 (permalink) Old 09-11-2011, 08:30 PM
Hi Charley - when using this method, is the rabbet already in place? If so, is a template or something used for the bearing to ride on?
John Schaben
jschaben is offline
post #7 of 10 (permalink) Old 09-12-2011, 06:58 PM
CharleyL's Avatar
First Name: Charley
If you are putting a molded edge on the wood there is usually wood below the molded edge area that the bearing rides on. When you reach the corner and start down the next edge the router bit will leave a radius of the molded profile the radius of the bearing on the bottom of the bit. The best way to find out is to rout a profile around the inside of a picture frame or hole in a piece of wood. You would insert the profile bit desired in the router collet and then set the depth of the profile. The bearing on the end of the bit will go against the inside edge of the frame below where the profile is being cut. Once the depth is set, place the router on the frame or edge of the hole, turn it on, and bring the router bit against the frame. Now move the router in a counter clockwise direction around the inside edge of the frame. When you reach the corner simply continue around it and down the next side. Now look at the corner that you just cut. You will see the radius that I'm talking about.
Charley
post #8 of 10 (permalink) Old 09-12-2011, 07:22 PM
Charley
Got you on that Charley. But if you put the rabbet in first, there wouldn't be much of a surface for the bearing to ride on.
John Schaben
jschaben is offline
post #9 of 10 (permalink) Old 09-12-2011, 07:27 PM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Pointed frisbees are very dangerous! Route first and miter last and be very careful with those small parts. There have been several past threads showing some quite useful and economical "small parts holders". This forum is very user-friendly and nicely indexed! Good luck and stay safe - you don't want a nickname like "Lefty" <haha> OPG3
OPG3 is offline
post #10 of 10 (permalink) Old 09-12-2011, 07:48 PM
1 PC 1/2 SH Picture Frame Stepped Rabbet Router Bit | eBay
routing lettering on the edge of a plank safetyspot General Routing 6 06-27-2011 04:25 AM
Routing outside edge of a circle barryaclarke Table-mounted Routing 1 12-10-2010 08:34 AM
Routing edge inlay Shortcut General Routing 6 08-09-2010 09:57 PM
routing a previously routed edge Fishbaydoc Router Bits - Types and Usage 7 08-31-2009 11:40 PM
Routing edge on plywood Dimitri Guest General Routing 2 10-20-2004 02:34 PM
