Router Forums (https://www.routerforums.com/forum.php)
-   General Routing (https://www.routerforums.com/general-routing/)
-   -   Baseplate hole not centred (https://www.routerforums.com/general-routing/308-baseplate-hole-not-centred.html)
cbrandsm 10-14-2004 02:55 PM
I used to own a Ryobi router and could never maintain a bit centered in a baseplate bushing so I assumed that there was too much slop in the router. So I bought myself a new skil router and made a baseplate using a different router (from work) but the same model. The first time I used a pattern bit I could tell that it was going the slightly cut my brass bushing on the one side. After my second cut it had cut right throught the bushing. Is there something I did wrong or is there something I can do to prevent this? :'(
Chris.
reible 10-14-2004 05:49 PM
Chris.
Would you happen to have a digital camera? If so a picture of what you have would help decide what needs to be done. Something is very wrong as you can tell but without knowing more details it is hard to answer.
For further reading check:
www.routerforums.com/showthread.php?t=163
I wrote a couple of articals and one is about aligning sub-bases.....
Ed
FineHomesCarpentry 10-24-2004 01:29 PM
I can recommend the trend uni-base. It fits most routers and comes with a centering tool. The base allows the use of all trend guide bush's.
They retail at abot 15.00 (sterling)
Powered by vBulletin® - Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
