Not to sure why you would want to do that, 3/8" shank router bits are hard to come by in the states, but if you are saying that all your Craftsman routers use 1/4" bits only you are SOL now if they are 1/2" collet you can get Adapter Bushings that will let you use the 3/8" shank bits easy..
And you are right as usual. There is no such animal to convert to a 3/8" collet. Next question, I have a craftsman router table and craftsman router installed. Looking down on the shaft, the rotation is counterclockwise. With the fence running left to right, and a 1/4" bit installed in the chuck which direction is proper to run a piece of blank stock to cut a 1/4" mortise? Right to left, or left to right? Thanks, Gumball
Right to left. If the router was on top of your work then it would be left to right but for a table it is right to left.
Related Threads
747K posts
128.1K members
Since 2004
