Makita 3612C collet problem - Router Forums
post #1 of 11 (permalink) Old 01-12-2012, 02:17 PM Thread Starter
Default Makita 3612C collet problem
I have a Makita 3612C router that I have had for years. When it was new, I could change bits with no problem, but as time went on, when I tried to remove/change bits, the collet nut would loosen but the collet would not. I have never bottomed the bits out or abused the router in any way. I took it to a Makita dealer (with a bit still in it). They informed me that Makita had a problem with this particular router, but that there was no cure for the problem. I can change bits out, but a hammer and punch is not the way to do it, (common sense!). Has anyone else had this problem? If so, what was the solution? Thanks for any and all help.
Bill
W C Slad is offline
post #2 of 11 (permalink) Old 01-12-2012, 07:34 PM
G’day
Welcome to the router forum.
Thank you for joining us, Bill.
I, and a few of the forumites, use this router and I have not heard of this problem before.
I think the Makita dealer was trying to sell you a new router.......
Are you able to remove the nut and collet completely from the router with the bit still attached?
If not, you may have cross threaded the nut.
Are you able to just buy a replacement nut/collett?
Sorry, I cannot help any more that that. I Harrysin was around I am sure he would be able to help as he has a couple of Makita routers...
Sydney, Australia
jw2170 is offline
post #3 of 11 (permalink) Old 01-13-2012, 08:14 AM Thread Starter
Thank you jw for your reply. I can take the collet nut off w/o any problem, so not cross threaded. I do not remember if I can remove the collet with the bit still in it (old age, I guess). I have tried everything that I can think of short of buying new collets. For some reason, they just are not releasing. I will try what you suggested and get back to you. Thanks again.
Bill
W C Slad is offline
post #4 of 11 (permalink) Old 01-13-2012, 10:19 AM
Hi Bill
Bill
post #5 of 11 (permalink) Old 01-13-2012, 11:34 AM Thread Starter
Bob,
As jw suggested, I attempted to remove the collets, had a 1/4" in the router, but neither one would come out w/o some persuasion. I tried just the 1/2" collet with a bit, but the same problem presented itself-the collet would not release the bit. Also, the collet nut loosens, but does not have a place where it feels tight, thereby loosening the bit when turning more. Before buying replacement parts, I blew the collet housing and collets off good, but with no luck. Sooooooooo.....I guess I will bite the bit (no pun intended) and order parts. Thanks for your reply.
Bill
W C Slad is offline
post #6 of 11 (permalink) Old 01-13-2012, 08:13 PM
Hi Bill,
Please Let us know how you get on.
I did not think of BJ's idea.
Come to think of it, I buy 1/2" shank bits for my Makita and for my Triton.
Some bits fit the Makita but are very tight in the Triton and some bits fit the Triton and are very tight in the Makita. Go figure?
Have you changed brand of bits?
Sydney, Australia
jw2170 is offline
post #7 of 11 (permalink) Old 01-14-2012, 12:00 AM
TWheels's Avatar
Bill,
What kind of wood have you worked with? I am thinking the oils and gum from the wood have "gummed up" the works.
It sounds like at this point you do have a major parts replacement issue on your hands.
I too own a Makita 3612C and have only three issues with it: the requirement for a collet adapter sleeve for 1/4 and 8 mm shank bits, the pushbutton and wrench collet tightening as opposed to a two-wrench system, and the one-year warranty. Mine did have a problem shortly before the one year lapsed, but no problems since then. Otherwise, it is a fine router. The light (torch in Harry's lingo) on the replacement model would be a welcome addition.
I Want to Be the Person My Poodles Thought I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #8 of 11 (permalink) Old 01-14-2012, 02:25 AM Thread Starter
Tom,
I have mostly worked with oak, ash, walnut, etc. I have worked with woods that have either been kiln dried or had a low moisture. Can't remember working with sappy woods and there didn't appear to be any residue on the collets, etc. I have had this router for quite a few years, however, and have used it on many projects so I could be wrong. When you say major parts replacement issues, are you speaking of new collets and nut or something more?
Thank you for your reply and happy woodworking!
Bill
W C Slad is offline
post #9 of 11 (permalink) Old 01-14-2012, 02:33 AM Thread Starter
Originally Posted by jw2170 View Post
Hi Bill,
Hi James,
I have used Craftsman bits and two other brand bits (1/4 and 1/2" shanks) and seem to have the same problem. I can see the bit shank length being different, but the diameter should be standard....????? As you said, go figure. Thanks.
Bill
W C Slad is offline
post #10 of 11 (permalink) Old 01-14-2012, 11:03 PM
TWheels's Avatar
Tom,
Bill
Hi Bill,
I so far have worked almost exclusively with pine or whatever white wood the nearby big box stores have. They contain a lot of pitch and I have learned that cleaning my router bits when they seem to get dull can restore them well; I was applying the same logic to you situation, but clearly not the case.
Hi Bill,
I was specifically referring to your post which I quoted below and the part I have made bold. Rereading it now I see that I misread it, so my comment is "inoperative".
Bob,
Bill
Thanks, and I look forward very much to it warming up enough for me to get back to routering. Best of luck to you so you can get back in action.
TWheels is offline
Makita 3612c problem. mjbiffo Tools and Woodworking 1 11-23-2011 12:21 PM
Problem with Craftsman router collet barking spider General Routing 4 01-16-2011 09:18 AM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 01:33 PM
Makita 3612C TWheels General Routing 8 11-23-2008 07:58 PM
