Help! Stanley dome top - Page 2 - Router Forums
post #11 of 19 (permalink) Old 04-01-2013, 10:07 PM
First Name: Todd
Default stanely "R2D2" dome-top Router (H-39-B)
Hello,
I was lucky enough to find one of these great little routers at a flea market for $15. Could not pass it up. It even has the guide. It is if fairly good shape and the bearings sound great. Looks Identical to the photos in this thread. I cleaned it up and checked the brushes. Cord is not original but that is to be expected with a piece this old. Serial no is CU5150, 4.0 A, 115V. Any idea of the age based on this? I know from what I have read that this basic Stanely Carter design dates back to the late 20's which is pretty cool. Also is an manual out there for this router? It would be great to have it. Thanks.
Todd
todd.l is offline
post #12 of 19 (permalink) Old 04-01-2013, 11:22 PM
Chris, no parts are available for any of these routers.
post #13 of 19 (permalink) Old 06-18-2013, 03:10 AM
First Name: Frank
Default primitive Stanley shaft lock
I have an old Stanley it has no locking button; there is a hole that goes through the motor shaft located just above the collet nut. I use a heavy tapered scratch awl through the hole and let it jamb up against the base while tightening or loosening the collet with an 1 1/4" wrench. I suppose that a straight pin punch of the proper size would also be a good tool for the job.
FC333 is offline
post #14 of 19 (permalink) Old 01-03-2014, 06:22 PM
OET
OET's Avatar
First Name: Olin
Any chance someone could send me a drawing of the wiring under the dome top or a picture of it. My power cord was disintegrating (original) and I cut it under the top without drawing the wire connections or taking a picture.
Sometimes I get tired of re-learning from previous lessons learned.
OET is offline
post #15 of 19 (permalink) Old 07-26-2015, 03:11 PM
Default Stanley H14a Router (R2D2)
Don't know if anyone has answered, but on the top of dome is a round button (flush with top). Just push that down and it will lock the motor so you can tighten the bits in the collet. I ended up with my dad's ole router. I started using this unit when I was about 8 years old, am now in my 70's. Don't know when my dad purchased this, but it was new and for a router, has about equivalent of a million miles on it". He was a cabinet maker and used it all the time! Along with that, I also have his old delta 2 inch belt sander and other equipment. These are all stored in some of the best carry caress you could buy in the late 40's-early 50's. 50 caliber ammo boxes. Carry well and protect even better. 1 for router, 1 for electric drill, and one for 2" belt sander. Along with these, is the 8 inch Delta table say and 4 inch jointer. All still work well, but currently stored away due to lack of space at new house.
dummydave is offline
post #16 of 19 (permalink) Old 10-29-2017, 04:13 AM
Country: France
Default Stanley H13B
Is there anyone with a working Stanley H13B router - If so is there any chance you could send me a picture of one of the brushes and take some measurements so I can manufacture a couple to fix my old router
Jumbosailore is offline
post #17 of 19 (permalink) Old 07-30-2020, 06:35 PM
I have one. Do you still need specs?
Shafif is offline
post #18 of 19 (permalink) Old 07-30-2020, 07:09 PM
A generous offer but he joined solely for that one post in 2017 and hasn't been back since.
post #19 of 19 (permalink) Old 07-30-2020, 07:46 PM
Was it something we said?
DaninVan is offline
Work bench top hdusch Project Plans and How To 5 04-05-2015 03:09 PM
Table top display cse. derek willis Show N' Tell 16 04-13-2014 06:31 AM
Router table top? Rick in Pittsburgh Table-mounted Routing 11 09-26-2010 09:24 PM
How to best attach router table top to cabinet? xvimbi Table-mounted Routing 3 05-28-2010 07:30 AM
Office cubicle table top for router top Noob Table-mounted Routing 12 05-23-2009 07:35 AM
