elu manual - Router Forums
post #1 of 12 (permalink) Old 04-26-2012, 10:02 AM Thread Starter
First Name: steve
Default elu manual
A friend gave me an old ELU router. Not sure of the model. It has the number 3338 on it. I was looking for a manual for it when I stumbled onto this site. I have tried to follow the hoops to get to here. Not sure what an Avatar is other than a movie about blue folks. I have been a Rockler customer for many years. If anyone knows where I can obtain an old manual I appreciate the help.
manute1 is offline
post #2 of 12 (permalink) Old 04-26-2012, 09:35 PM
Welcome to the router forum.
Thank you for joining us, Steve.
Sydney, Australia
jw2170 is offline
post #3 of 12 (permalink) Old 04-26-2012, 10:30 PM
Steve, an avatar is the small image posted with your name online. James and I both use our photos but others may have cartoons or logo's.
The Elu routers evolved into DeWalt and that is your best shot at parts or manuals.
post #4 of 12 (permalink) Old 04-27-2012, 05:47 PM
Phil P's Avatar
First Name: Phil
Hi Steve
The Elu 3338 was the US version of the Elu MOF177e. Today the same router continies as the deWalt DW625e. See CASparky's post in the DeWalt section of the manuals forum for the DW625
Regards
Phil
Phil P is offline
post #5 of 12 (permalink) Old 04-30-2012, 09:23 AM Thread Starter
First Name: steve
thanks a lot
manute1 is offline
post #6 of 12 (permalink) Old 05-02-2012, 04:01 AM
Country: Belgium
First Name: André
Hi Steve
My name is Andrew,you can call me Andy or André,i am from Belgium.
I am in the posession of different machines from ELU and also the router MOF 177.
Thisone is about 20years y think,i also have one MOF 98 he is about 25 to 30 years
i think.
Here in Europe they were the second best after SCHEER these have the most heavy handheld machines.
I also have a few smaller routers from ELU,some drilling machines a table saw,som sanders,circel and bandsanders and a tool ho drives the workpiece along the table of a big routermachine ( i dont now the name in English. )
Ok so fahr so good i also attached 4 pictures, that was it so i send an other reply with some more pictures.
Sorry if i make mistakes in English writing.
Regards
andré54 is offline
post #7 of 12 (permalink) Old 05-02-2012, 04:18 AM
Country: Belgium
First Name: André
Default manual
Hi Steve,[B]
here some more pictures from the manuel.
Nice regards to the US
Two times i was in Florida,i hope to come back sone.If somebody needs to now someting from this side of the ocean ask me...
Ok i have tried to upload some more jpeg's but it dit not work,i try it some other time.
andré54 is offline
post #8 of 12 (permalink) Old 05-07-2012, 07:34 AM Thread Starter
First Name: steve
Default Thanks for the help
I retired last week and hope to get in my shop more now. I appreciate you folks helping and hope to seek your help with routing applications in the future. The old ELU looks like a nice machine. I have used the porter cable model with interchangeable bases (can't think of the model number) for the last few years.
manute1 is offline
post #9 of 12 (permalink) Old 10-04-2012, 11:07 PM
First Name: Boris
Default ElU Router
Hi,
I recently obtained used ELU 177/02 Type 2 router 12A.
It looks as everything works fine except RPM is fluctuating when machine is running without load and speed is set to 4 or less. Is it normal?
And another question, is 12 amp router sufficient for average hobby use, or better to find a 15 amp one?
Boris12345 is offline
post #10 of 12 (permalink) Old 10-08-2012, 04:56 PM
Phil P's Avatar
First Name: Phil
Hi Boris
On the MOF177e (the variable speed model) the motor speed should be fairly constant but it can be affected by a number of things:-
(i) Power supply to the router - this needs to be a thick enough cable to supply the power and the cable run should not be too long. Are you running the power through a long extension cable?
(ii) Brushes need to be in good order. Not much of an issue as these aren't to expensive to replace and aren't too difficult to replace
(iii) Bearings. When disconnected from the power does the shaft turn smoothly?
(iv) Variable speed controller. These sometimes fail. The router can be wired without this unit in place in which case it will run as a single speed (22,000 rpm) router - a useful test.
As to 12Amps being sufficient, I'd rather say that these routers (MOF177e s) are rated very conservatively at 1850watts over here (on 110 volts) and have more than sufficient power for industrial and trade use. My own typ 2 is well over 25 years old and still going strong - and I'm a tradesman
Regards
Phil
Phil P is offline
Instruction Manual wayoutwest General Routing 5 05-25-2016 09:11 AM
ELU MOF177E type4 porshiepoo General Routing 3 08-27-2011 10:04 AM
Elu BobDz General Routing 1 08-09-2010 10:11 PM
How to add a Manual Mark Power Tool Manuals 0 04-01-2010 08:00 PM
ELU DS140 / DeWalt DW685 Jointer istracpsboss Tools and Woodworking 0 01-09-2009 09:21 AM
