Searching for a collet? - Router Forums
post #1 of 13 (permalink) Old 05-17-2013, 12:10 PM Thread Starter
Default Searching for a collet?
Members often post that they are looking for an odd sized collet. Up until now the best option has been to order an adapter sleeve to use in a larger collet. Adapters work and are cheap enough but I prefer to use the correct sized collet for the job... just one less thing that can go wrong. That is why I wanted to tell you about Elaire Corporation. Elaire offers the best selection I have found in collets, collet nuts and adapters. These are high precision and made of US alloy steel. Popular Bosch, Milwaukee and Porter Cable collets are listed but others are available. If you need a collet or adapter they do not already have available they will custom manufacture one for you. The photo shows some collets I got today; it is easy to remove a collet from the collet nut and snap one of these in. If you are searching for a collet check them out here: Elaire Corporation -Router Collets
If you call with questions or to order be sure to let them know you heard about them on routerforums.
Name:	Elair collets.jpg
post #2 of 13 (permalink) Old 05-17-2013, 01:52 PM
post #3 of 13 (permalink) Old 05-18-2013, 07:18 AM
Daikusan's Avatar
Country: Japan
First Name: Steve
Any idea if the Bosch collet will work on a Craftsman? It looks identical.
I need 6mm.
Workmanship is not perfection; it is how well you can cover your mistakes.
Daikusan is offline
post #4 of 13 (permalink) Old 05-18-2013, 07:36 AM Thread Starter
I doubt it Steve. What is the model number?
post #5 of 13 (permalink) Old 05-18-2013, 02:40 PM
markm's Avatar
First Name: Mark
Default Eclaire collets are made in the u.s.a.
Be sure and let them know you saw their collets on this forum. I ordered a 7, 8, and a 10mm set from them in May 2012 for my PC890 routers and they work fine.
Made in the USA.
Mark
markm is offline
post #6 of 13 (permalink) Old 05-19-2013, 01:38 AM
First Name: Dick
Default RotoZip.
BJ I thought I was the only one that paid any attention to these little 'mighty mites'. I have purchased 3 0f these RotoZips on eBay. Each came with the case, 1/4&1/8 collets, fixed base, and edge guide and some bits. They are the higher end units and never had to pay over $15 (I think). Two of them had never been used and one showed some wood dust. They are great for breaking edges with a 1/4 roundover or chamfer bits. I gave 2 of them away, one to my son and one to a close friend. My son and I leave them set up in the shop, one for chamfering and one for roundovers. They have much more power than most people think...
Where there's a Willis there's a way!
Willway is offline
post #7 of 13 (permalink) Old 05-19-2013, 05:52 AM
Daikusan's Avatar
Country: Japan
First Name: Steve
Model 320.27680 14.0A Variable Speed both 1/2 and 1/4 collets.
I have your doubts too but if the OD of the collet is the same I could swap nuts if necessary.
By the way have you ever used Japanese "Supra" bits? I would like to know how they compare to other bits.
Daikusan is offline
post #8 of 13 (permalink) Old 05-19-2013, 06:51 AM
Country: Japan
First Name: singh kuldeep
Send a message via Skype™ to samurai
Steve could you please give me more information about Supra bits.where i can find them.any web link?
samurai is offline
post #9 of 13 (permalink) Old 05-19-2013, 08:17 AM
Daikusan's Avatar
Country: Japan
First Name: Steve
Singh
I have bought the bits at both at Joyful Honda and Handy. The company is ライト精機株式会社(大阪市). Here is a picture.
By the way its "Super" not Supra as I mentioned. Sorry.
Just found a link http://www.monotaro.com/k/store/%83%...0%83r%83b%83g/
Daikusan is offline
post #10 of 13 (permalink) Old 05-19-2013, 08:53 AM
Country: Japan
Singh
Just found a link ライト精機 トリマー ビットの販売特集 - 通販サイトMonotaRO
thanx!!
samurai is offline
Precision Collet Recommendation? clarksvilleal General Routing 6 03-15-2013 08:45 AM
Broken Router Collet deanr Table-mounted Routing 12 10-26-2012 12:52 PM
MY PC 7518 collet was junk, I replaced it with a Precision Collet what a difference. Bill Huber General Routing 0 09-25-2012 11:52 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
