Trend T4 repair? - Router Forums
post #1 of 5 (permalink) Old 05-18-2014, 10:46 AM Thread Starter
Country: Sweden
Default Trend T4 repair?
Hi all.
I'm new to this forum - found it today when my Trend T4ek died on me.
i started to disassemble the machine, as I bought it from Ebay and it would be too much of a pita to send it back and forth and so on.
Anyhow - what I found was that the small cable to the field coil (#22mtmc.co.uk/Trend-T4-Router-Spare-Parts__p-36365.aspx) had been worn off - as if it has been in contact with the rotating armature (#26www.mtmc.co.uk/Trend-T4-Router-Spare-Parts__p-36365.aspx).
(Had to write the links in this way, due to forum-rules.)
I didn't want to take it apart so much when not knowing how to disassemble the armature, so I was wondering if anyone here knew?
I removed all of the bottom parts, so it seems the armature is loose. Is it a press fit in tho top bearing or how do I remove the armature?
Can this small cable be soldered with just a shortening of the damaged area (about 2 inches) and of course new coating?
Or - should I buy a new field coil or perhaps a new router and keep this for spare parts?
Is it possible to purchase just the router motor from somewhere or does one have to buy the entire kit?
Thanks in advance
/ Jonny
jonny.westin is offline
post #2 of 5 (permalink) Old 05-19-2014, 12:50 AM
Hi Jonny, welcome to the forum.
Sydney, Australia
jw2170 is offline
post #3 of 5 (permalink) Old 05-20-2014, 11:10 AM
Country: Sweden
First Name: Jonny
Hi again - and thanks for the welcome.
I got eager to continue with my routing, so I went trial-and-error on my Trend.
When disassembled, all I had to do was to pry the field coil out of the hosing to get the clearance needed for me to solder.
There was a lot of wiring to handle, and to solder that coil-cable wasn't the easiest - but now it's done.
Will keep up with this forum, and maybe post some pics of my work with this machine.
Best regards
/// Jonny
jonnywestin is offline
post #4 of 5 (permalink) Old 05-20-2014, 12:18 PM
Semipro's Avatar
First Name: John_*
Jonny, really pleased to see you join the community, welcome to Router Forums!
Thank You John
Semipro is online now
post #5 of 5 (permalink) Old 05-20-2014, 06:50 PM
old55's Avatar
First Name: Ross
Welcome to the forum Jonny.
Ross,
old55 is offline
Trend Combo Routing Base (CRB) Relative Jigs and Fixtures 1 11-06-2013 08:52 AM
Patio chair repair JFPNCM Show N' Tell 10 07-26-2013 07:48 AM
Trend Plunge Router Ken Bee General Routing 5 11-15-2011 01:40 PM
Oval Mirror Repair 747trace General Routing 4 12-01-2010 11:53 AM
Trend T4EK versus Bosch Colt thistlefly Portable Routing 15 06-09-2010 02:38 PM
