Small Circle Cutting (no centre hole) - Router Forums
post #1 of 15 (permalink) Old 05-20-2014, 02:31 AM Thread Starter
First Name: Stu
Default Small Circle Cutting (no centre hole)
Hi Guys I'm new to the forum and live in Australia
At the moment I'm making a few knick knacks (jewellery) in between making guitars.
The main thing I am struggling with is cutting small circles (between 1.5 and 2 inches in Diameter (30-40mm)). I don't really want to use plug cutters as I'm sure there is a way to do it with the tools I have (small bandsaw, router, drill press, laminate trimmer)
The circles would be easy to cut if I wanted a centre hole, but I want there to be no centre hole. I don't mind if there is a pin hole on the back side as I can fill that with epoxy/ filler. I'm mainly using highly figured curly timbers (scraps) and when I tried out the jig pictured below, the wood just split down the curly/ fiddle back grain lines (leaving 3/4 of a circle.)
The stock I'm using is about 2-4 mm thick
I was also wondering if a similar jig would work better on a scroll saw (the blade might be a bit close to the clamp though...)?
Other alternatives. I could just program the circle into Cad and get them Laser cut. that would cost about 100 bucks for a few hundred circles.
Cowbell is offline
post #2 of 15 (permalink) Old 05-20-2014, 04:08 AM
Smile
Welcome to the forum, Stu.
Sydney, Australia
jw2170 is offline
post #3 of 15 (permalink) Old 05-20-2014, 06:22 AM Thread Starter
First Name: Stu
Cheers James!
There's some cool stuff on here
Cowbell is offline
post #4 of 15 (permalink) Old 05-20-2014, 07:00 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
The fact that your material is very thin indicates that the hole goes right through, that being the case why can't a Forstner bit be used, look on Gumtree for a cheap drill press and problem is solved.
Drill press | Power Tools | Gumtree Australia Kingston Area - Cheltenham | 1046571981
The hole can of course be routed by making a template and using a template guide and suitable bit, the simple formual for calculating the size of hole in the template is:
diameter of template guide minus diameter of bit plus diameter of finished hole, ie:
50mm hole required, using a 30mm guide with a 6mm bit gives us:
30 - 6 + 50 = 74 mm hole in the template which can be made using a circle routing jig, details of a simple to make one are in this pdf.
I'm having to assume that you have a reasonable amount of woodworking experience because you forgot to complete your profile which ensures meaningful answers. Being in Australia you may well live close to me in Rockingham WA in which case I would be happy to give you all the help that you need.
Harry
harrysin is offline
post #5 of 15 (permalink) Old 05-20-2014, 08:05 AM
First Name: Jake
Hi Stu,
You can use a hole saw bit with the centre drill bit removed if you clamp the timber to your drill press table.
I only watched this video this morning.. Woodturning with Tim Yoder, Ep. 4: Making Colored Pendants - YouTube
Tim does it towards the startoif the video (you just have to get thru the 2.5mins of ads at the start).
Jake
Jakexp is offline
post #6 of 15 (permalink) Old 05-20-2014, 08:07 AM
PawPawRay's Avatar
First Name: Ray
I make wooden earrings and cut the circles from 1 inch dowels using a miter saw. I can cut 150 in about 20 minutes.
Visit http://pawpawsworkshop.etsy.com to see finished product.
PawPawRay is offline
post #7 of 15 (permalink) Old 05-20-2014, 09:11 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Hi Stu - welcome to the forum - have a read through this thread from a while back, where some of us discuss making circles without central holes. The table saw jig works well with just a small pivot underneath, but the small size of your circles would be a worry, as you would be having your fingers rather too close to the blade for comfort.
http://www.routerforums.com/show-n-t...ert-rings.html
Wildwood is offline
post #8 of 15 (permalink) Old 05-20-2014, 10:38 AM
Shortslvs's Avatar
First Name: Fred
Have you thought about using a lathe? You could cut a length of whatever the lathe can hold then bandsaw to thickness.
I would do it that way, but your material thickness might be what you are stuck with and therefore my answer is bad.
Fred Ritzendollar
Owner Ritzendollar Woodworking
CNC Router Service - Signs, parts, embellishments
1800BunkBed providing service from Springfield to Branson
https://m.facebook.com/bunkbedritz?r...f&notif_t=like
Shortslvs is offline
post #9 of 15 (permalink) Old 05-20-2014, 11:03 AM
Santé's Avatar
Country: Belgium
First Name: Daniel
Hello
This jig will solve all problem for small holes or small pieces
it is in english
http://www.lescopeaux.asso.fr/Techni...de_Anglais.pdf
Member of the french site for woodworkers
Santé is offline
post #10 of 15 (permalink) Old 05-20-2014, 11:10 AM
Gaffboat's Avatar
First Name: Oliver
Originally Posted by Santé View Post
Hello
it is in english
That is a clever and interesting jig, Daniel. Thanks for posting it.
Gaffboat is offline
holeless circle cutting pauli mac Jigs and Fixtures 50 01-25-2012 12:37 PM
Cutting a Circle rjg202 Tools and Woodworking 15 11-12-2011 08:44 AM
Cutting very small pieces on table saw simplenik Tools and Woodworking 13 08-16-2007 06:10 PM
Drilling large hole over small hole or vice-versa simplenik Tools and Woodworking 8 06-13-2007 07:57 PM
