Plunge Router with least amount of deflection - Router Forums
post #1 of 35 (permalink) Old 05-22-2014, 10:22 PM Thread Starter
RainMan 2.0's Avatar
Default Plunge Router with least amount of deflection
Guys I have a makita plunge router and I have made mistakes before as the router had moved a tiny bit while plunging in some areas creating small imperfections on the sides .
Is there a proven router out there that doesn't do this? I have a pc690 also and somewhere there is a base that you can change out to plunge but I've never used it free hand as it's mounted to my TS so I don't know if PC is an improvement .
Is there a particular brand or model you guys favour. Thanks in advance
I just had a thought , maybe your not supposed to use your router perpendicular to the material?
RainMan 2.0 is offline
post #2 of 35 (permalink) Old 05-22-2014, 10:34 PM
Bosch for me..
and yes, perpendicular is a suppose to...
is the router moving in the base as you plunge because it is loose or are you moving the router it's self... are you using a guide???
post #3 of 35 (permalink) Old 05-22-2014, 10:45 PM Thread Starter
Yes it happens when your following a guide . I would be scared to cut the excess material from a counter top as it moves a tiny bit side to side in its base . Maybe they all do a little but I suspect there's a better brand .
Was debating to give it away and try a new PC model
post #4 of 35 (permalink) Old 05-22-2014, 11:56 PM
My 1617 nor 1619 Bosch(s) don't do that... not even the Colt...
My PC does...
Maybe there is a fix for your Makita...
I believe the the castings on the PC leave a lot to be desired..
One other thing... Because of the casting the PC motor isn't concentric to the base...
drove me nuts till I figured out the issues....
the baseless motor is now in a router lift/table.....
My take is that Bosch machines their motor housings and bases to fit as where PC puts their's to use as is hot from the mold w/o any machining...
smoothness of movement and no binding is very apparent in the two because of this.....
Also... I have found that Bosch outlasts PC by a wide margin... Both used at production level...
post #5 of 35 (permalink) Old 05-23-2014, 12:15 AM
How much/deep are you plunging in one take???
too much at a time is not a good thing...
post #6 of 35 (permalink) Old 05-23-2014, 12:38 AM Thread Starter
Stick I'll check out Bosch . Thanks for your input as it's always appreciated
post #7 of 35 (permalink) Old 05-23-2014, 12:44 AM Thread Starter
Stick which Bosch would you recommend today ? I want one that fits router guides in the base plate to
Update :
The 1617 and 1619 are getting great reviews and seem to be the top routers .only complaint with the 1619 was operating the lock down lever with left thumb
post #8 of 35 (permalink) Old 05-23-2014, 01:15 AM
Update :
what are you cutting and how much of it???
post #9 of 35 (permalink) Old 05-23-2014, 01:37 AM Thread Starter
Was going to make a computer desk and coffee and end tables at some point in time . No heavy production but I really prefer quality tools if I know what to buy
post #10 of 35 (permalink) Old 05-23-2014, 02:07 AM
the 17 it is...
the 17 is a real work horse...
but..
look to the 23...
it has some really nice features...
I've read the complaints and after using it for some time (brutally) I think the complaints, for the most part, are operator failure and their failure to RTFM....
http://www.boschtools.com/Products/T...?pid=MRC23EVSK
Bosch plunge router base problem gwizz General Routing 20 03-16-2017 07:02 PM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
