Large routing bits - Router Forums
post #1 of 4 (permalink) Old 05-30-2014, 10:03 PM Thread Starter
First Name: Guile
Default Large routing bits
I was looking for a two to two and a half inch routing bit as recommended for a set of templates I just purchased. It was recommended for use on the router table with use of the guide pin or fulcrum. I found a Freud bit that was 2 inches. I was surprised by the size which turned out to be 2 x 2 inches....a monster. I obviously didn't read all the dimensions. I later found a 1/2 by 2 which suits my needs. I am thinking of returning it since it's so pricey but before I do I would like to know how I might be able to use this on other projects and whether any of you could share your experiences with the bit on the table and handheld. Thanks.
guile1 is offline
post #2 of 4 (permalink) Old 05-31-2014, 03:19 AM
Hi Guile, if you are using a guide pin or fulcrum, then you must be using a bearing guided cutter?
Is the cutter 2 -2 1/2" long or wide?
What template are you using?
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 05-31-2014, 08:30 AM Thread Starter
First Name: Guile
You are correct in that I am using a top bearing down spiral flush bit and it is 2 1/2 long. It is a cathedral template that is used for door making but I am looking to use it as a decorative piece that will be attached to the backboard of a DVD case I am building for my daughter. Also what type of joinery would u use. The back board and cathedral piece will be 3/4 inch oak about 16 inch wide adnd about 6 inches tall. I had thought about making just one piece but it seems like it would be a difficult or at the very least cumbersome to work with on a router table thought. Thanks for your thoughts.
guile1 is offline
post #4 of 4 (permalink) Old 05-31-2014, 09:14 PM
Hi Guile,
If I am reading you correctly, the template set up you are describing is very common.
The only thing I would add, is that your mark out and cut the waste back to 1/8" with a band saw or jig saw and use the cutter for a trimming cut, not a full cut.
Check out some of Marc's videos on youtube.
Sommerfeld's Tools for Wood - Shaker Raised Panels Made Easy with Marc Sommerfeld - Part 1 - YouTube
Sydney, Australia
jw2170 is offline
First bit set Mike Router Bits - Types and Usage 46 07-29-2015 08:56 AM
Whiteside dovetail bits not lasting long for me AronD Router Bits - Types and Usage 20 04-15-2013 01:17 AM
Laminated Hardwood Gunstocks- which bits?? tobnpr Router Bits - Types and Usage 3 02-05-2013 09:23 AM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
Magnate Router bits kp91 Tool Reviews 2 07-09-2007 03:36 AM
