aesthetic choice - Router Forums
post #1 of 7 (permalink) Old 06-15-2014, 07:02 AM Thread Starter
Default aesthetic choice
Hi all
I have to install a beech stave worktop in our kitchen. It's 40mm thick and will have a kick in the end so it will go down from approx 600mm to 500mm width over a distance of 30 cm. If I just rout it to shape ill end up with a lot of v edges on the front. On a fibreboard and melamine top you'd just cut and join. Anyone with experience like to advise? At the momeny I'm thinking of citing the angle and the glueing a piece of beech to the front to avoid a lot of v endings.
Ps I'm not metric really but the stuff you buy in the uk is!
Fraise is offline
post #2 of 7 (permalink) Old 06-15-2014, 12:40 PM
Al B Thayer's Avatar
First Name: Al
It's dificult to understand your question. Any pictures?
Al B Thayer is offline
post #3 of 7 (permalink) Old 06-15-2014, 04:41 PM Thread Starter
I'll do a drawing!
ps sorry about mistypings in the original post. I wrote it on a phone. it should be 'cutting' not 'citing'.
Fraise is offline
post #4 of 7 (permalink) Old 06-15-2014, 08:08 PM
Hi John, I have difficulty visualising all these v edges.
If you use a straight cutter ...?
Sydney, Australia
jw2170 is offline
post #5 of 7 (permalink) Old 06-25-2014, 06:34 AM Thread Starter
Default took me a while to be near a scanner
but I've attached a pdf here which should describe the problem. I just want to know if there is an industry 'standard' solution.
Fraise is offline
post #6 of 7 (permalink) Old 06-25-2014, 01:35 PM
Hey, John; if you're talking about the end grain at the mitred end, how about running something like a contrasting wood or 'Corian' edge all around the exposed perimeter?
Even a beech edge run continuously would look good.
Here's some ctrtop edge pics ...unfortunately not shown with wood work surface.
https://www.google.ca/search?q=Coria...w=1112&bih=532
DaninVan is offline
post #7 of 7 (permalink) Old 06-27-2014, 04:08 PM Thread Starter
Default Thanks Dan
your google search was a good clue. By adapting it I found loads of stave beech counter tops
Fraise is offline
Router Choice gmanhall General Routing 10 04-20-2014 04:05 AM
Cnc router choice ... batley12 CNC Routing 12 06-20-2013 04:30 AM
Best choice of wood for garage cabinet? jeep_man Tools and Woodworking 6 04-09-2009 06:18 PM
Delta Table Saw Choice rh111 Lobby 11 11-07-2006 07:24 AM
