How to bypass the trigger switch? - Router Forums
post #1 of 8 (permalink) Old 06-23-2014, 08:10 PM Thread Starter
First Name: Roy
Default How to bypass the trigger switch?
Hello to all..
I'm a newby who bought a used craftsman 315.174730 router which now won't run.
The trigger switch is no longer available, so I thought I would bypass it and use instead the master switch on the router stand.
However there are 5 wires (Black, white, red, yellow and violet) attached to the trigger switch and I can't get any readings that make sense on my voltmeter.
so... my question is:
Is the black wire the hot lead to the trigger switch and the white the neutral return? ... or...? (There are two red wires going to opposite ends of the trigger switch - wiring runs shown on pg 12 of the online manual).
Thanks in advance for your help,
Roy
roy111 is offline
post #2 of 8 (permalink) Old 06-23-2014, 08:16 PM
MT Stringer's Avatar
Originally Posted by roy111 View Post
Hello to all..
Roy
My one and only thought would be to throw it away and buy one that works.
MT Stringer is offline
post #3 of 8 (permalink) Old 06-23-2014, 09:31 PM
Welcome to the forum, Roy.
How old is the router? Is it worth repairing or replacing?
I, personally, do not like to mess around with the electronics on tools....
Sydney, Australia
jw2170 is online now
post #4 of 8 (permalink) Old 06-23-2014, 09:36 PM
Semipro's Avatar
First Name: John_*
Roy, welcome to Router Forums, glad to have you join us, I'm positive the members of the community would be more than willing to answer any questions you have
World wide forum some times it takes a while for members to get back to you
Thank You John
Semipro is online now
post #5 of 8 (permalink) Old 06-23-2014, 11:27 PM
BrianS's Avatar
First Name: Brian
On mine, 2 of the red wires feed a light in the base. The red wire coming from the motor is from a secondary winding in the motor to produce low voltage for the light. I would "think" that the black and white wires from the motor are what you would need to connect to, but DO SO AT YOUR OWN RISK as this is only a guess. I did not have a yellow or violet wire on mine, so have no idea what direction to suggest for those. Perhaps further disassembly might be in order to determine where those wires go if you can't determine by testing.
Not sure if it's of any help, but there are pictures of mine here: -craftsman-router-manual-anyone.html
Brian
(Origin uncertain)
BrianS is offline
post #6 of 8 (permalink) Old 06-24-2014, 02:14 AM
old55's Avatar
First Name: Ross
Welcome to the forum Roy.
Ross,
old55 is offline
post #7 of 8 (permalink) Old 06-24-2014, 08:41 AM
First Name: Duane
Bypassing the main power switch will only work if the main power switch is the problem.
It may not be!
There is an interlock switch actuated by the spindle lock mechanism(It actually is still available! Cost $25-30 with S & H). Also as I recall the multi conductor wire to the handle was problematic as well.
Then there is also the variable speed control that can cause the same problem.
I would want to troubleshoot and find the actual problem before attempting repair. Jumpering things without an understanding of what you are doing usually doesn't end well!
Also do consider that is about a 30-35 year old, or so, tool. I think I would just replace the tool.
Dmeadows is offline
post #8 of 8 (permalink) Old 06-24-2014, 06:18 PM
First Name: Kerry
Welcome......
Throw it away and start again seems good advise to me. Playing with power when one is unsure is not a good way to start. I'd invest in a later model and some reliability.
Cheers
Kerry
Anybody can become a woodworker, but only a Craftsmen can hide his mistakes!
-Walter Blodget
Larkan is offline
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 08:33 PM
Bosch Router Switch Problem bill kay General Routing 41 11-19-2010 08:29 AM
Lean Managed Switch Question MrCapuchino General Routing 2 07-27-2010 08:55 AM
Safety Power Tool Switch kmcbride21 Table-mounted Routing 12 12-23-2009 05:38 PM
***Urgent*** Switch problem uzzaljss Lobby 1 07-16-2009 11:27 AM
