cabinet insert replacement - Router Forums
post #1 of 6 (permalink) Old 06-24-2014, 01:59 PM Thread Starter
First Name: Gary
Default cabinet insert replacement
Would like to see video on removing cabinet insert with a hand router. Would like to replace wood panel with glass.
gwg7448 is offline
post #2 of 6 (permalink) Old 06-24-2014, 04:50 PM
Semipro's Avatar
First Name: John_*
Hey Gary, it's great to meet you and have you as a member of our community, welcome!
Here is one technique
DIY Changing Solid Cabinet Doors to Glass Inserts | Simply Rooms (by design)
Thank You John
Semipro is online now
post #3 of 6 (permalink) Old 06-24-2014, 05:14 PM
BCK
First Name: BC
welcome aboard...have you tried google for different videos on routing etc..
http://www.natures-lifestyles-digest.com/smf
above [link]site has: outdoors type things from fishing, hunting, boating, hiking, to living off grid, gardening from veggies to flowers etc, recipes from home cooking to smokers, hobbies, home remedies, to making your own soaps etc..live members chat area.. and more...all is welcome to browse or join..
BCK is offline
post #4 of 6 (permalink) Old 06-24-2014, 06:16 PM
RainMan 2.0's Avatar
Welcome to the forum
RainMan 2.0 is online now
post #5 of 6 (permalink) Old 06-24-2014, 06:20 PM
old55's Avatar
First Name: Ross
Welcome to the forum Gary.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is offline
post #6 of 6 (permalink) Old 06-24-2014, 06:26 PM
Welcome to the forum Gary. Removing the insert should be a relatively easy process. Unless you are familiar with using guide bushings then I would take a pattern bit and clamp a board to the door frame leaving 3/8" gap between the inside of the frame and the guide board and set the depth of the bit to the panel. 3/8" might not be quite enough but I would start there and then go to 1/2" which should be as wide as is needed. If the grooves for the panel are 1/2 inch deep then you can stick with that measure for the rest of the cuts. I would also clamp a board at each end of the guide board at the same offset to make sure you don't cut into to the frame too deep at the ends. You'll need to trim the rounded corners square with a chisel. All you need to do after that is to make some moldings to hold the glass in place unless you plan on just using caulk to do that.
If you know how to use guide bushings the process is pretty much the same except that you can use a straight bit instead of a pattern bit and you have to add the offset of the guide bushing when positioning the guide boards.
My Custom DIY Insert Plate / Router Table Project BRAVOGOLFTANGO Table-mounted Routing 21 10-17-2012 08:52 PM
getting right benchdog insert for bushings spoonjig New Member Introductions 2 03-05-2010 02:13 AM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
Fastening Router Table To Cabinet DONALD Table-mounted Routing 7 04-03-2005 11:04 AM
