centring kit - Router Forums
post #1 of 6 (permalink) Old 06-26-2014, 05:50 PM Thread Starter
First Name: Al
Default centring kit
I am trying to purchase a Rousseau centring kit to mount a Triton router to a Freud table plate Up to now I'm not even sure where to get one in Canada or shipped to Canada. Anyway. I wondered if the marking studs that screw into the router base will fit the Triton router. Rousseau give a list of models they make kits for but Triton is not even listed. Help !!! Al.
oldrusty is offline
post #2 of 6 (permalink) Old 06-26-2014, 07:53 PM
Hi Al,
I believe the PC7518 and a Milwaukee? router have the same hole settings as the Triton.
If they are listed, use those settings.
Once you have the router attached to the plate, you can use 5/16" ID guide bush to set the centre. Use a 1/4" drill bit in a 1/4" collet.
If you do not intend to use guide bushings in the plate, then centering to /1000" is not all that important...
Sydney, Australia
jw2170 is offline
post #3 of 6 (permalink) Old 06-27-2014, 12:26 PM
First Name: Dick
Al try to pick up a Dewalt centering kit locally. They just use a cone to center the router in your plate. Quick, easy, and cheap.
Dick
Where there's a Willis there's a way!
Willway is offline
post #4 of 6 (permalink) Old 07-03-2014, 06:20 PM
First Name: Michael
The Triton plate screw holes are exactly the same as the PC 7518 router. Use that kit and you're good to go.
Michael H is offline
post #5 of 6 (permalink) Old 07-03-2014, 10:02 PM
Honored Member
First Name: pat
On the same centers (screw hole circle) but not the same screw.
Quillman is offline
post #6 of 6 (permalink) Old 07-08-2014, 12:54 PM Thread Starter
First Name: Al
Hi Asim. The cost to me in Canada was around $6.00 plus postage direct from Rousseau. I can't say what the cost to you would be. The problem for me is that they don't make a kit for the Triton router at this time. Al.
oldrusty is offline
For Sale: FS: Akeda DC16 dovetail jig + accessory kit chrisexv6 Woodworking Classifieds 4 01-12-2011 08:44 AM
another kit or a dedicated table router? rprice54 General Routing 11 08-06-2009 07:51 AM
