bosch 1617 router - Router Forums
post #1 of 12 (permalink) Old 07-03-2014, 08:49 AM Thread Starter
reelwood's Avatar
Default bosch 1617 router
Hello,
My Bosch router 1617 won't do anything when i attempt to start it ,it was fine two weeks ago when i last used it. No power ,no noise ,nothing. I have tried cleaning it with compressed air,nothing works any thoughts on that.I thought that maybe the brushes went bad. In the meantime I purchased the the same router at lowes so it would work on my table and other accessories as i was in the middle of some home improvements. What now.....
reelwood
reelwood is offline
post #2 of 12 (permalink) Old 07-03-2014, 09:50 AM
BCK
First Name: BC
welcome aboard....might be the switch or wiring??try posting in appropriate area for more and better responses......enjoy
http://www.natures-lifestyles-digest.com/smf
above [link]site has: outdoors type things from fishing, hunting, boating, hiking, to living off grid, gardening from veggies to flowers etc, recipes from home cooking to smokers, hobbies, home remedies, to making your own soaps etc..live members chat area.. and more...all is welcome to browse or join..
BCK is offline
post #3 of 12 (permalink) Old 07-03-2014, 11:40 AM
Forum Moderator
Semipro's Avatar
First Name: John_*
John,Hello and welcome to router forums
How old is this router
Thank You John
Semipro is offline
post #4 of 12 (permalink) Old 07-03-2014, 05:32 PM Thread Starter
reelwood's Avatar
It's about 4 years old,but prior to this it showed no sign of quitting on me no funny smell. I had made several pieces of molding cleaned it up then nothing?????
John
reelwood is offline
post #5 of 12 (permalink) Old 07-03-2014, 05:58 PM
Welcome to the forum, John.
Thank you for joining us, .
You will find many on the forum, from hobbyists
to professional with similar interest in the router and its uses.
Sydney, Australia
jw2170 is offline
post #6 of 12 (permalink) Old 07-03-2014, 06:17 PM
First Name: Michael
John, give Bosch a call. Older models of this router have had switch failure problems. Might be your issue. They have sent replacement switches for free in the past.
Michael H is offline
post #7 of 12 (permalink) Old 07-03-2014, 06:59 PM
old55's Avatar
First Name: Ross
Welcome to the forum John.
Ross,
old55 is offline
post #8 of 12 (permalink) Old 07-04-2014, 06:54 AM
First Name: Gary
John, Most Bosch tools use what they call "smart brushes". What they have done is embed a spring loaded plastic finger into the carbon brushes. When the brushes wear to a predetermined size the finger contacts the commutator and pushes the brushes away from the commutator to tell you it's time to replace. You might want to remove the brushes first to see if that is the problem.
gmercer_48083 is offline
post #9 of 12 (permalink) Old 07-04-2014, 08:09 AM
First Name: PAD3
I have had the same problem. It is the on/off switch that is the probable problem (Occam’s Razor) and the solution is to have Bosch send you a new one. Just call the toll free number. It is a very simple operation to change one. To keep the router working take the switch out, open it, clean the switch, replace and the router will probably start. Practice for replacing the switch when the new one arrives.
PAD3 is offline
post #10 of 12 (permalink) Old 07-06-2014, 07:20 PM Thread Starter
reelwood's Avatar
good ideas, I will get on it in the morning
reelwood is offline
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Bosch Router theenglishman1 Table-mounted Routing 8 12-31-2012 07:04 AM
Adapting a Bosch 1617 router glfinneyirish Table-mounted Routing 4 01-02-2012 08:11 PM
