Chipping edges - Router Forums
post #1 of 10 (permalink) Old 07-05-2014, 04:50 AM Thread Starter
First Name: Peter
Default Chipping edges
I'm making a drum shell and was trying to level the edge with a router. I put the router on a stand (approx 5.5" high) and put the shell under it. I've found that it has chipped the edges. It was a straight router bit, it was parallel to the grain and I removed less than 1mm. Is this normal, and could it be fixed with a better router bit? I do have an extra long router bit that I could try, and it was much more expensive.
My router bit was part of a set, so it's probably not the best and I have already used it to round off the outside of an oak shell.
The shell is pine, but I wanted to do the same to an oak shell. Fortunately the pine shell is for practicing and the finish was already poor (lots of knots etc.).
DrillingThrough is offline
post #2 of 10 (permalink) Old 07-05-2014, 05:02 AM
are you routing w/ the grain or across it???
new or used bit???
Stick486 is offline
post #3 of 10 (permalink) Old 07-05-2014, 11:25 AM Thread Starter
First Name: Peter
new or used bit???
Across the grain. The bit was new when I got it but I've rounded the outside of an oak shell with it.
post #4 of 10 (permalink) Old 07-05-2014, 11:50 AM
I trust you have a real quality bit like a Freud, CMT or a Whiteside....
WTB that the chipping occurs when you get to end of your cut...
some things to try...
sacrificial piece of material at the end of your cut...
shallower cuts...
learn to climb cut the ends..
if the chipping is happening everywhere.. get a replacement bit...
Stick486 is offline
post #5 of 10 (permalink) Old 07-05-2014, 01:50 PM Thread Starter
First Name: Peter
shallower cuts...
The bit is a cheap brand, I may try a better brand.
A sacrificial piece would probably work, but as the shell is round it's not quite so simple.
post #6 of 10 (permalink) Old 07-06-2014, 09:34 AM
rwl7532's Avatar
First Name: Ralph
All your staves should have been the same length so when you glued them up the edge should have been more or less level.
Mount sandpaper (I use 80 grit paper with adhesive backing) to a piece of plywood.
And sand the edge flat with that setup.
The setup pictured was before I attached the sandpaper permanently.
An alternative to leveling the edge is on a table saw with a high fence. The shell abuts the fence on one end and the shell is carefully rolled and the saw blade cuts the other end.
You still have to make your bearing edge, right? What kind of profile are you going to use? Double 45s, round over? Making you bearing edge will remove wood so the chip out may not be an issue. The heads and hoops will cover much of what is left.
Get a camera and share pics.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #7 of 10 (permalink) Old 07-06-2014, 12:10 PM Thread Starter
First Name: Peter
I've found the cause of the problem. I was going the wrong way. I need to go one way for the outside and the other way for the inside.
My shells were a little too tall anyway, so sanding would have taken a long time. The oak shell has turned out ok. The pine shell will still have some chips after cutting the bearing edge, but the ring will hide it. I may put filler on the pine one anyway and then just paint it.
post #8 of 10 (permalink) Old 07-06-2014, 01:17 PM
rwl7532's Avatar
First Name: Ralph
Too tall is how much in either inches or metric?
rwl7532 is offline
post #9 of 10 (permalink) Old 07-06-2014, 03:07 PM Thread Starter
First Name: Peter
It was about 5.5mm too tall. It's the right height now, although I need to sand the edges a bit.
post #10 of 10 (permalink) Old 07-06-2014, 04:54 PM
rwl7532's Avatar
First Name: Ralph
And the reason the staves weren't cut to size in the first place is??
rwl7532 is offline
23 ga Pinning into MDF edges? BigJimAK Table-mounted Routing 58 10-15-2013 09:36 PM
Show me your edges noone Router Bits - Types and Usage 1 05-14-2013 08:53 AM
Bread Knife Template - Using router table to round over the edges bkramme Jigs and Fixtures 2 09-18-2011 05:25 PM
How to best dress up the edges on Rockler table top? xvimbi Table-mounted Routing 2 08-06-2010 02:39 PM
Leigh Jig & Tails on Edges (vs. pins) FlyMaster Jigs and Fixtures 2 10-16-2007 10:10 AM
