Leaving Bit in Router Between Uses - Router Forums
post #1 of 46 (permalink) Old 07-10-2014, 07:19 AM Thread Starter
Contributor of the Month
Default Leaving Bit in Router Between Uses
Is there any reason not to leave a bit in a router when not in use? I'll be using the same bit periodically throughout a project (slot cutting bit to re-groove hardwood flooring) which will extend over a 10 - 15 day time period. I've got the height dialed in and would like to leave the bit and router in the table.
JIMMIEM is offline
post #2 of 46 (permalink) Old 07-10-2014, 07:32 AM
tvman44's Avatar
First Name: Bob
I am no expert but I leave mine till I need something else.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #3 of 46 (permalink) Old 07-10-2014, 07:47 AM
JOAT's Avatar
First Name: Theo
I leave mine in until it needs a new replacement. Dunno how long the present bit has been in there (the one I normally use for what I do), but it's been over a year I am sure. No problems. If I need a different style bit I just put in a different router, with the bit I want.
JOAT is online now
post #4 of 46 (permalink) Old 07-10-2014, 08:05 AM
do it on a regular basis...
if I need to change bits or settings I just bring another router into play instead of changing what's dialed in...
I spline a lot... the slot cutter has been left in the D handle for a very very long time...
same for the dado (4x's) and RO's..
post #5 of 46 (permalink) Old 07-10-2014, 08:44 AM
First Name: Clay
That is one reason I have many routers so I can leave them set up.
fire65 is offline
post #6 of 46 (permalink) Old 07-10-2014, 08:48 AM
exactly...
post #7 of 46 (permalink) Old 07-10-2014, 09:08 AM
I spline a lot...
I knew there had to be someone else here besides me Stick. Not sure what everyone else has against it.
post #8 of 46 (permalink) Old 07-10-2014, 11:26 AM
every panel I make is splined...
after you have experienced creep in a large panel - spline it is...
no creep...
flatter panels..
flusher joints...
way stronger over a butt joint...
faster more accurate assembly...
more glue surface...
less omni directional movement..
less/limited joint separation..
stronger miters...
they like speed and relying solely on the glue to get where they are going....
post #9 of 46 (permalink) Old 07-10-2014, 01:03 PM
MT Stringer's Avatar
+1 What he said.
MT Stringer is offline
post #10 of 46 (permalink) Old 07-10-2014, 08:56 PM
I tend to remove mine, particularly on the routers that are not used very often.
Had one stick some time ago and do not want this to happen again.
Sydney, Australia
jw2170 is offline
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
Correct way to install a router bit Goldglv Router Bits - Types and Usage 22 04-07-2010 09:46 AM
