help me find parts ? - Router Forums
post #1 of 9 (permalink) Old 07-10-2014, 05:00 PM Thread Starter
Default help me find parts ?
I have a cadillac of a router that i have grown up useing in the shop with paw paw . For the first time in twenty years i flip the switch and nothing . through a small investigation i discover that the brushes or bushings what ever you call them have gone bad . i tried to find replacement locally but no luck.. does anyone know where i can find them it is the power kraft router motor model TEB-8542A made by montgomery ward . any help would be greatly appreciated !!!
dlusby3 is offline
post #2 of 9 (permalink) Old 07-10-2014, 06:03 PM
Welcome to the forum.
Sydney, Australia
jw2170 is offline
post #3 of 9 (permalink) Old 07-10-2014, 06:47 PM
CharleyL's Avatar
First Name: Charley
Welcome to Router Forums dlusby3. I'm sure you will like it here.
Please take the time to update your profile (Top right of screen).
I doubt you will ever find original parts for your Montgomery Ward router, but all is not lost. Stanley made many routers for MW, but they discontinued their models many years ago too so finding Stanley brushes that fit will also be nearly impossible.
Brushes are just sticks of hard, pressed together graphite, so any brush that will fit into the brush guides of your router can be made to work. Does the original brush have a wire and spring attached? you will need to find one like that or your job will be much harder. Many of the better mom and pop type hardware stores in the US have a stock of many sizes of brushes. You will need to take one of your brushes with you and try to match up the design, of course your's will be shorter since it's worn out. If you find some that are close in design, but slightly too wide or too thick you can sand them down or even shorten them with a sander (messy job) until they fit into your router. They need to fit, but they need to slide easily.
Good luck,
Charley
Central North Carolina
CharleyL is offline
post #4 of 9 (permalink) Old 07-10-2014, 07:07 PM
old55's Avatar
First Name: Ross
Ross,
old55 is offline
post #5 of 9 (permalink) Old 07-10-2014, 08:06 PM
First Name: Duane
Sears bought out Wards part inventory. Likelyhood of finding them with original part number is very slim. But... measure the brushes, and you can probably find replacements. Other parts? Not so much!
Here is one of many place you may try...
http://www.graphitestore.com/cat.asp/spcat_id/3
Here is another...
http://store.eurtonelectric.com/brushes.aspx
NOTE: measure accuratly! Recommend a dial or digital caliper.
Dmeadows is offline
post #6 of 9 (permalink) Old 07-10-2014, 08:58 PM
Forum Moderator
Semipro's Avatar
First Name: John_*
Hello, glad you found us, it's great to have you as a member of the community, welcome to Router Forums.
Like Charleyl said small motor repair shop may have bushings and brushes that will fit
Thank You John
Semipro is online now
post #7 of 9 (permalink) Old 07-11-2014, 09:06 AM
smitty10101's Avatar
First Name: smitty
Send a message via Yahoo to smitty10101
You may also try an automotive repair that rebuilds starters, generators, and alternators
smitty10101 is offline
post #8 of 9 (permalink) Old 07-12-2014, 04:15 AM
First Name: cabosawman
Default brushes
if you have the old one I found brush on e bay I order 1 brush not a pair from sears and it was over $10 dollars I took the size and found 10 pair for less than 10 dollars of course it can from china and it took a month to get here but now i have 10 pair ,just make sure the spring is the right length you might have to file off the sides a little , but I can put up with a little work to find WHAT I NEED AND TO SAVE SO MONEY
cabosawman is offline
post #9 of 9 (permalink) Old 07-12-2014, 04:41 AM
tool repair parts cabinet at DoitBest.com - The World's Largest Hardware Store® ...
Stick486 is offline
Segmented Bowl Jerry Bowen Tools and Woodworking 7 06-29-2012 12:41 PM
Jig and Fixture parts kit from Lee Valley Cherryville Chuck Tools and Woodworking 6 05-27-2012 03:24 PM
Used router Missing Parts tkleff General Routing 3 02-13-2012 12:27 AM
Acquiring parts for Freud router bnainCalgary General Routing 2 10-27-2011 03:07 PM
re600 parts, among other parts dutchman 46 General Routing 0 07-08-2011 03:05 PM
