Finessing router adjustments/alignments to OCD levels - Router Forums
post #1 of 10 (permalink) Old 07-12-2014, 04:03 PM Thread Starter
Default Finessing router adjustments/alignments to OCD levels
What methods, KISS/MISS techniques has everyone worked out to get where they need to be???
For depth/set bak I found this... easy, fast and simple...
cheap too...
http://www.trend-uk.com/en/US/produc...imperial_.html
More for the depth... sweet...
but not cheap...
https://www.kregtool.com/store/c41/r...le-setup-bars/
for absolute centering to fences or guides... this... comps for the dia and cutters all on it's own...
go with SAE and metric guides...
very cheap...
Westcott C-Thru Circle Templates - BLICK art materials
since Bosch routers are 3" CL to base edge virtually religiously this works great to set an edge guide to the cut's CL...
no fuss no muss or compensating...
Veritas® Precision Square - Lee Valley Tools
for those obscure dado widths I set up a pair of parallel clamp on guides with a sliding spreaders to maintain spacing and an undersized shallow cut bearing guided mortising bit..
Stick486 is offline
post #2 of 10 (permalink) Old 07-12-2014, 11:46 PM
Forum Moderator
Semipro's Avatar
First Name: John_*
I use the trend also this one
Thank You John
Semipro is offline
post #3 of 10 (permalink) Old 07-13-2014, 01:10 AM
RainMan 2.0's Avatar
Stick I guess I should invest in one of those someday
Ok ,I never insulate
RainMan 2.0 is online now
post #4 of 10 (permalink) Old 07-13-2014, 08:42 AM
First Name: Ellery
Being a machinist I use dial indicators, dial calipers, micrometers, adjustable parallels, key stock, etc. to set up my tooling. It is second nature to me. I like repeatability. To some it my seem like overkill. It is just how I was taught. My thanks to all of the great craftsmen that I have worked with.
When I set up my EZ Pro dovetail jig for the first time I used an adjustable parallel to set the bit height, and the fence height. I made the cut. Perfect the first time. Instead of making a test cut and adjusting until I got it right, I got it right, then I cut.
Precision measuring tools do not lie.
Thanks to everyone for all of the helpful posting. I always learn something new.
Ellery Becnel
Arcola60 is offline
post #5 of 10 (permalink) Old 07-13-2014, 08:49 AM
First Name: Ellery
Also, I leave my router bits in my routers until I have to change them. I like having more than one router. I keep telling my sons, you can never have too many routers, or clamps!
Arcola60 is offline
post #6 of 10 (permalink) Old 07-13-2014, 01:37 PM Thread Starter
also have a dead really really old Bosch set up with a centering pin..
rare use but it sure comes in handy some times...
Stick486 is offline
post #7 of 10 (permalink) Old 07-14-2014, 05:37 AM
I use brass set up bars, and If i get REALLY finickity on the table saw I use the Dial Indicator.....
Sydney, Australia
jw2170 is offline
post #8 of 10 (permalink) Old 07-14-2014, 08:01 AM
First Name: Duane
Ellery Becnel
I like that statement, Ellery!
I am not a machinist, but I do use my dial caliper much of the time. It's easy, accurate, and just takes out a lot of guess work.
I also use a digital height gauge similar to the Trend. Got a super price on it a while ago, and I like it a lot, especially for odd height's that my brass setup bars won't do!
Also for accuracy and repeatability, I really like my Incra jig
Dmeadows is offline
post #9 of 10 (permalink) Old 07-14-2014, 05:06 PM
First Name: Ellery
Thanks Duane, I do not have a digital depth gauge YET. It is on my list. I reference .000 from table to top of cutter with a dial indicator. I have the original Incra jig. I like it a lot.
Arcola60 is offline
post #10 of 10 (permalink) Old 07-21-2014, 04:42 PM
First Name: Brad
I have all of those tools but they do not get used much any more. I just use a ruler that stands on its own and set the bit height close. Then I use a micrometer to measure depth of cut on a test piece. My router lift gives me the capability to make a final adjustment needed to be dead on.
Just remember what my father always said, " Half the people in this world are below average!", and everything in life will make a hellova lot more sense.
timbertailor is offline
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 11:44 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
Which Router To Get Etc? Gaia General Routing 10 02-24-2010 04:52 PM
