stuck RE1802M Ryobi - Router Forums
post #1 of 3 (permalink) Old 07-16-2014, 06:03 AM Thread Starter
First Name: Jerry
Default stuck RE1802M Ryobi
Was given the above router which comes with three bases. The router adjusts height or allows bases to be changed by turning the "depth adjustment ring". The router had not been used in a while and I cannot turn the ring. I have use compressed air and a gentle mallet, but can't twist the ring. Any help appreciated. Jerry
Loophole is offline
post #2 of 3 (permalink) Old 07-16-2014, 08:40 AM
I suggested using a little heat to someone else who had the same problem and he said it worked. It will soften and expand the plastic ring which may be enough to get it moving. I suggested a heat gun but he didn't have one and used his wife's hair dryer instead which was good enough it seems.
post #3 of 3 (permalink) Old 07-16-2014, 10:51 AM Thread Starter
First Name: Jerry
thanks. heat worked, but ring turns hard. blew out router but still difficult to turn. spayed some silicone based bicycle chain lube on it. don't care is unit damaged from spray. what good is a router if you cannot adjust depth of cut. what a bad design. Jerry
Loophole is offline
Ryobi depth adjustment stuck arigger General Routing 27 03-12-2016 12:26 AM
Ryobi Straight Edge Guide doesn't fit Ryobi RE180PL1 Router BabyGerald General Routing 1 09-16-2011 07:31 PM
New router use w/ Ryobi 1801M1 router 1/4 inch collet RexM Router Bits - Types and Usage 1 04-11-2011 04:37 PM
Ryobi height adjust. stuck arigger New Member Introductions 1 02-09-2011 07:05 PM
