Router chatter with spiral bit - Router Forums
post #1 of 6 (permalink) Old 07-19-2014, 02:01 PM Thread Starter
Default Router chatter with spiral bit
Hey Everybody!
I have a Leigh 1/2" Spiral Bit (its the 180CL), so its the carbide bit that is 2 1/2" long. I've been trying to do some plunge mortises and I get insane chatter. Even as its first plunging, it chatters a lot. If I switch to my 1/2" HSS spiral bit (which is only about 1 1/2" long), then I get an easier plunge cut. I get these really bad banging around sounds and the plunge gets increasingly difficult and dangerous. Any ideas why this is happening? I bought this beautiful carbide bit and I haven't been able to use it. I've been routing with both the festool OF1400 and the Triton 1400w router. I get better results with the festool but still the same problem overall.
Thanks in advance
loked is offline
post #2 of 6 (permalink) Old 07-19-2014, 07:38 PM
If that is the only cutter which gives you the chatter, it sounds like a bad cutter.
Sydney, Australia
jw2170 is offline
post #3 of 6 (permalink) Old 07-19-2014, 09:03 PM
First Name: Duane
Are you trying to plunge full depth in one pass? Try taking out the waste in much smaller steps and work your way down to full depth.
Dmeadows is offline
post #4 of 6 (permalink) Old 07-19-2014, 09:28 PM
set it a little bit deep into the collet...
post #5 of 6 (permalink) Old 07-19-2014, 09:40 PM
First Name: Clay
Question answered. You are taking to much wood per cut. I have big routers and good bits and I still take 3 to 5 passes depending on what I am cutting.
fire65 is offline
post #6 of 6 (permalink) Old 07-19-2014, 11:54 PM
Al B Thayer's Avatar
First Name: Al
I had a Colt router that could not center the bit. Took it back and the next one was the same. Exchanged that one and still couldn't get one to center the bit. Gave up on the Colt.
Put a gage on the bit and see if the bit is bad. The above fore mentioned were 12 thou out.
Al
Al B Thayer is offline
Stuck router bit latebloomer Router Bits - Types and Usage 6 09-07-2012 08:34 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
