Routing a glued up panal - Router Forums
post #1 of 14 (permalink) Old 07-23-2014, 11:20 AM Thread Starter
First Name: Barry
Default Routing a glued up panal
I know there will be a lot of "ifs" in answering this question but I feel it's worth asking since it might save me days with my projects.
I glue up small panels usually consisting of two to four boards. Overall size of the panels range from 6" X 12" up to 24" X 24". All my wood is 4/4 and is usually hardwood although I use a lot of pine for my prototypes and jigs. My usual glue is Titebond II. I work in my basement where the average temperature is around 62 F and low humidity. My joints consist of edge to edge glue only joints. No biscuits, dowels or screws.
My question is this. How long do I have to wait for the glue to dry before i can work the panel. I'd like to cut it to final size and finish all of the edges on the router table as soon as possible without screwing up the panel. I currently glue up the panel, come back in 30 to 45 minutes and scrape off the squeeze out then come back again in about an hour and remove the clamps. Here's the part i question. Since the glue bottle says to wait 24 hours before stressing the joints, i wait until the next day before doing any final milling to the panel. Is the 24 hour wait time necessary? I know that if i'm too quick, and the glue isn't totally dry i'll gum up the router bit and i'm also afraid that if i'm too quick the panel may change its dimensions as the moisture from the glue leaves the panel.
If any of you work in similar conditions please let me know what your experiences have been and any other advice you can give me? With a limited number of clamps along with a limited work area it can take me days to get all the panels completed. I'd really like to reduce that time but not at the risk of ruining the project.
Barry747 is offline
post #2 of 14 (permalink) Old 07-23-2014, 12:39 PM
Semipro's Avatar
First Name: John_*
I would not router in less then 24 hours, but you can pull the clamps after 45 minutes so glue and clamp all the panels today and router tomorrow. We all would like to rush the project but through my experience I usually pay for it, and lose time and have to start over.
Semipro is offline
post #3 of 14 (permalink) Old 07-23-2014, 12:40 PM
JOAT's Avatar
First Name: Theo
I always wipe the squeezeout right away. I always (normally) let the glue go 24 hours. Just in case. In any event, I can always find something else to do with my shop time while I'm waiting on it to set. There was a thread a short time back about an instant glue, and apparently instant is the word to describe it, put it together wrong, and you get instant adhesion. You might want to check on that stuff. I started the thread, but am not in the mood just now to hunt it down and provide a link.
JOAT is offline
post #4 of 14 (permalink) Old 07-23-2014, 01:12 PM
MT Stringer's Avatar
When making glued up panels for doors, I pull the clamps after 45 minutes and sit it aside and do another one. I have room and clamps for two panels, and sometimes three.
I always set my timer on my smart-alec phone so I know when to remove the clamps. It is easy to get distracted. At least it is for me.
Good luck.
MT Stringer is offline
post #5 of 14 (permalink) Old 07-24-2014, 07:03 AM
First Name: Richard
Send a message via Skype™ to rwbaker
I've done a lot of glue-ups similar to yours during the last 3 years in a outdoor shop and like most I use 24 hours as a minimum (with clamps) and try to let it sit for 24 more hours without. I've found that Tight-Bond takes a lot longer below 75F than above but never less than 24 hours, even at 90+F. High Humidity (35~45%) and 55F or below can take as long as 4 days. Elmer's, Gorilla wood glue (no urethanes) and the Harbor freight store brand seem to follow the same rules. These have been my experiences and I hope they help - Baker
rwbaker is offline
post #6 of 14 (permalink) Old 07-24-2014, 09:22 AM Thread Starter
First Name: Barry
It sounds like at least 24 hours to set up before additional milling is the right way to go. I'll stick with what I'm doing and not try to cut any corners (pun intended). Thank you all for your feedback. I appreciate it.
Barry747 is offline
post #7 of 14 (permalink) Old 07-24-2014, 11:49 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Barry.
I usually make some wooden splices by placing a slat that fits into a dado routed on the edges of each piece. Previously I put white glue and later, I insert the slat, clamp the assembly and let it for overnight, after that I continue with the process (cut to length, HPL application and so on)
We, woodworkers are everywhere!!!
papasombre is offline
post #8 of 14 (permalink) Old 07-24-2014, 01:05 PM
kywoodchopper's Avatar
First Name: malcolm
Hi Barry, I am not an expert on any subject, but I can tell you how I glue up. Since the instructions says not to subject the wood to stress for 24 hours, my panels are never subject to stress. I use Titebond II glue and I purchase in small bottles. Once open I throw away after 6 months. If I am gluing a table leg, chair leg, table top, etc. I leave clamps on over night. For box tops and panels which won't be under stress I leave the clamps on 2 hours or so. On all glue up, I dry clamp to make sure everything fits properly. I put enough glue to cover all edges. If using porous wood I make sure both boards get plenty of glue. After clamping I immediately use damp towel to remove excess glue.
Yesterday I glued up three pieces of tiger maple for a box top. I left one board about 7" longer than the others so when I run them through the planer I don't snipe the wood. I left the clamps on a couple hours, removed the clamps and ran the boards through the thickness planer, sanded them, cut to size and applied a coat of finish within 4-hours of start resawing the boards. I have never had a glue failure with 40-years experience. Malcolm / Kentucky USA
kywoodchopper is offline
post #9 of 14 (permalink) Old 07-24-2014, 06:02 PM
lenh's Avatar
First Name: Len
+1 for Malcom. I do exactly the same thing. I have even routed a decorative edge after a couple hours. I never noticed any problem with glue gumming up the bit. As stated, table legs, chair parts, or other structural parts I leave dry overnight. Think about it - after glue up you still have to shape, sand, and finish. That means it is always more than 24 hours before the joint put under stress of any kind. Not recommending this - but I've turned spindles on a lathe after only 3 hours of glue up. The key is to have tight fitting joints to begin with.
lenh is offline
post #10 of 14 (permalink) Old 07-24-2014, 09:25 PM
First Name: Dick
I have to agree with Malcolm and Len. I think it depends greatly on humidity and temperature. Here in hot, dry west Texas I have tried to separate freshly glued pieces after about 1/2 hour, and could not separate them without destroying them. We use Titebond II almost exclusively.
Dick
Where there's a Willis there's a way!
Willway is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
old person new to routing in wood sailer670 New Member Introductions 12 12-13-2014 07:31 PM
Routing a lip on a box or the back of a picture frame after it has been glued up Harvey Dunn General Routing 1 05-16-2014 12:37 PM
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 04:24 AM
