Clockwise or counter clockwise when circle cutting? - Router Forums
post #1 of 11 (permalink) Old 07-23-2014, 07:14 PM Thread Starter
Dutchmn's Avatar
First Name: Dutch
Default Clockwise or counter clockwise when circle cutting?
Clockwise or counter clockwise, what is the proper direction to route when using a circle jig and a straight bit? Does it matter? ( I go counter clockwise)
Dutchmn is offline
post #2 of 11 (permalink) Old 07-23-2014, 07:23 PM
OutoftheWoodwork's Avatar
First Name: Barb
I can't honestly say, Dutch. When I'm cutting around the outside of a sign, I get less resistance, or a smoother run when I go clock-wise. There have been other things when cutting that I get better cuts going counter-clockwise. Of course, I don't use a table.
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is offline
post #3 of 11 (permalink) Old 07-23-2014, 07:32 PM
First Name: Clay
Depends on the wood, the sharpness of the bit and how much you are taking off. I usually climb cut until the last pass and then I take 1/64", just to smooth it up.
fire65 is offline
post #4 of 11 (permalink) Old 07-23-2014, 09:56 PM
Question
Hi Barb, when going around the outside, you should go counter clockwise.
If you are going clock wise, you are climb cutting. I believe it feels like less resistance as the cutter is actually moving, very slightly, out from the workpiece.
Sydney, Australia
jw2170 is offline
post #5 of 11 (permalink) Old 07-23-2014, 10:36 PM
Honored Member
First Name: pat
Inside pathway cutting: Then it doesn't matter much.
(assume you never cut all the way through in one pass.)
After one rev I'd make one reverse trip to clear the chip.
Outside cuts should be staged and climb cut in small increments to avoid tearout. Take the full thickness in one cut, and the router will self feed in end grain and you'll lose control. Stage cuts only in a climb.
Same with inside ring cuts. Must be staged whence climbed (CCW).
Always test on scrap in very shallow increments.
Climb cutting or any routing is full of surprises.
Quillman is offline
post #6 of 11 (permalink) Old 07-24-2014, 11:47 AM
First Name: Danella
Being left or right handed would make the most difference - correct?
beemor is offline
post #7 of 11 (permalink) Old 07-24-2014, 01:04 PM
First Name: Barb
Even with just a round over James? (I usually set my round over to just take of the edge... to smooth off the point.)
Barb
Mark Twain
Henry A. Kissinger
post #8 of 11 (permalink) Old 07-24-2014, 01:31 PM
twallace's Avatar
Country: Trinidad and Tobago
First Name: Thomas
I go anti clockwise on the outer perimeter.
twallace is offline
post #9 of 11 (permalink) Old 07-24-2014, 03:01 PM
hankh's Avatar
Country: Israel
First Name: Hank
Isn't it an issue of moving the wood into the cut of the bit? If so, going clock-wise on a router table should mean counter-clockwise when using a plunge router. What am I missing here?
hankh is offline
post #10 of 11 (permalink) Old 07-24-2014, 03:16 PM
Semipro's Avatar
First Name: John_*
Here is the simple way to remember( with the right hand palm down put thumb against the edges you want to router go the way your index finger points.
Which if you check outside edge counter clockwise inside edge is clockwise
Of course everything in reverse on router table
Semipro is offline
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
Cutting a Circle rjg202 Tools and Woodworking 15 11-12-2011 08:44 AM
cutting small circle with circle centre outside toadhall Jigs and Fixtures 12 12-06-2009 01:46 AM
