Elu 177e - starts when it feels like it. - Router Forums
post #1 of 14 (permalink) Old 08-07-2014, 06:26 AM Thread Starter
First Name: Helen
Default Elu 177e - starts when it feels like it.
Hi guys,
I've a 1992 Elu 177e that is reluctant to turn on. The brushes have been replaced and that sort of improved matters by virtue of it actually starting up, but now it can be up to a minute between flicking the switch and the motor beginning to turn.
What's going on?
Cheers,
Lon.Furnitureschool is offline
post #2 of 14 (permalink) Old 08-07-2014, 06:37 AM
First Name: Duane
Variable speed? If so probably the speed control module. I f you comfortable with electronic repair, probably a bad cap, that easily changed if the board isn't potted!
Dmeadows is offline
post #3 of 14 (permalink) Old 08-07-2014, 09:40 AM
I've also seen routers do that that had the on/off switch packed up with sawdust. It wouldn't hurt to try and blow it out with compressed air.
post #4 of 14 (permalink) Old 08-07-2014, 06:33 PM
old55's Avatar
First Name: Ross
Welcome to the forum Helen.
Ross,
old55 is online now
post #5 of 14 (permalink) Old 08-07-2014, 11:50 PM
RainMan 2.0's Avatar
Ok ,I never insulate
RainMan 2.0 is online now
post #6 of 14 (permalink) Old 08-08-2014, 07:34 AM
First Name: Gary
Helen, Due to the HAZARD that can occur by it switching on at random, I suggest you find a repair shop that can diagnose the problem. There are so many things that can cause this from faulty switches, dead spot in the commutators, bad connection, cord wire strands broken from being over stressed, arcing at commutators can be caused by wear from the old brushes... then when you install the new ones they don't match the wear pattern so they arc and cause heat which weakens the spring tension on the brushes which in turn causes more heat! In short , have it looked at by a compitant tech!
gmercer_48083 is offline
post #7 of 14 (permalink) Old 08-08-2014, 10:58 AM
It's Over 30 years old! Replace it; it owes you nothing!!
You'll spend almost as much repairing it as a new one will cost.
DaninVan is offline
post #8 of 14 (permalink) Old 08-08-2014, 10:54 PM Thread Starter
First Name: Helen
Thanks one and all for the swift response. Looks like it's time to either junk it or hand it over to someone who knows a thing or two.
Cheers
post #9 of 14 (permalink) Old 08-09-2014, 01:29 AM
Originally Posted by Lon.Furnitureschool View Post
Hi guys,
What's going on?
Cheers,
I had a girl friend like that once . Can't remember the fix though
post #10 of 14 (permalink) Old 08-09-2014, 01:40 AM
I knew her too...
you were the fix...
Stick486 is offline
Dis-assembly of an ELU 177E (DeWalt 625), how? janaf DIY and Renovation 9 02-01-2012 02:07 PM
Elu MOF 177e - Bearing Replacement shedhappy General Routing 6 08-31-2011 01:21 PM
ELU 177E Motor SPeed Problem hypnoscope Portable Routing 11 07-27-2011 03:08 PM
height adjuster for elu 177e jack dusty General Routing 6 05-24-2011 05:01 AM
Elu Mof 177e Router Keith Nilra Starting Off 3 06-02-2010 12:30 PM
