Throw-away tracing material - what kind? - Router Forums
post #1 of 8 (permalink) Old 08-07-2014, 12:53 PM Thread Starter
Default Throw-away tracing material - what kind?
What material do most folks use for tracing a shape?
Capitals is offline
post #2 of 8 (permalink) Old 08-07-2014, 01:02 PM
Gaffboat's Avatar
First Name: Oliver
I'm not sure I understand the question. I use a pencil and paper, Sketchup and a laser printer, or a scanner and printer to copy/trace a shape.
Or do you mean something, like in your image, that serves as a template? In that case I usually use 1/4" or 1/2" mdf.
Gaffboat is offline
post #3 of 8 (permalink) Old 08-07-2014, 01:15 PM Thread Starter
I'm looking for a material the bearing runs along during a flush cut. The meterial that is taped-on top or bottom.
Sounds like MDF is what's used rather than Masonite.
Capitals is offline
post #4 of 8 (permalink) Old 08-07-2014, 01:24 PM
RainMan 2.0's Avatar
So far all I've ever used is mdf , works for me and it used to be fairly inexpensive, easy to sand imperfections , easy to make a template with .
I always use a dust mask regardless of what I'm cutting ,but mdf is the worse for producing a really fine dust IMO , so I suggest wearing a mask if your working with it .
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 8 (permalink) Old 08-07-2014, 06:54 PM
JOAT's Avatar
First Name: Theo
Yep, for tracing pencil and paper.
For routing around, I use two layers of 1/2" plywood glued together. And I don't toss them, unless I make a revised version. I used MDF once, hated the dust.
JOAT is online now
post #6 of 8 (permalink) Old 08-07-2014, 08:46 PM
Semipro's Avatar
First Name: John_*
Hello
Are you asking what people are using to make temples,
First is it a one time use or are you planning to make dozens, nothing wrong with Masonite for making six or seven copies,I use 1/2" birch plywood if it something I want to keep forever,then there is long lasting acrylics
Semipro is online now
post #7 of 8 (permalink) Old 08-08-2014, 04:02 AM
N'awlins77's Avatar
First Name: Lee
I use carbon copy paper (purple sheets) for tracing a printed sketch from the puter, to a piece of wood.
Porelon Typewriter Carbon Paper Black 8 12 x 11 Pack Of 25 by Office Depot
N'awlins77 is offline
post #8 of 8 (permalink) Old 08-24-2014, 11:29 PM
jaximus's Avatar
First Name: jack
i use MDF, 1/4" to 1/2" thick depending on what project im working on/how deep i need to cut. i use 1" straight bits, with the bearing nearest the collar. i make templates big enough that the router plate has to rest on the template. with gun stocks, there isnt much material to keep the router square otherwise
jaximus is offline
duck profile tracing woodman12 CNC Routing 0 03-12-2014 07:57 PM
Routing material between the fence and bit mpbc48 Table-mounted Routing 10 02-27-2011 03:16 PM
Trouble initializing material.. or table? JCPowell CNC Routing 0 11-11-2008 08:30 AM
Table top material questions majn555 Table-mounted Routing 18 11-06-2008 09:49 AM
does anyone know what kind of material this is? unlimitedwoodworker Lobby 20 09-14-2008 11:53 PM
