New to routing and having problems already. - Router Forums
post #1 of 11 (permalink) Old 08-07-2014, 01:19 PM Thread Starter
Bushwhacker's Avatar
First Name: David
Question New to routing and having problems already.
I have a Bosch RA 1181 router table and a Bosch router, with 1/2 in Collet.
My problem is setting up for my rail and stile bits. I see that Rockler sells set up jigs, but how do I know which one to buy. My bits are Roman Ogee, a 2 piece set.
Bushwhacker is offline
post #2 of 11 (permalink) Old 08-07-2014, 01:21 PM
RainMan 2.0's Avatar
Welcome to the forum David. I'm sorry I can't help you but are others that will chime in soon
Ok ,I never insulate
RainMan 2.0 is online now
post #3 of 11 (permalink) Old 08-07-2014, 01:49 PM
what exactly are your problems and whose bit (brand) are you using???
can you link us to the jigs???
post #4 of 11 (permalink) Old 08-07-2014, 02:08 PM Thread Starter
First Name: David
My rail and stile bits are made in China and sold under the name of CAL-Hawk. I found the set up jigs on the Rockler site. But they only list one jig and don't say whether it is a Roman Ogee or what. I brought a piece of wood that I routed into the computer and tried to match it up with their jig, but it is not the same.
post #5 of 11 (permalink) Old 08-07-2014, 02:15 PM Thread Starter
First Name: David
I cut a stile and then tried to match the ends of my rails with it. I used a scrap piece and kept making adjustments until I got the depth of the cut right, then when I attempted to adjust the up and down cut, it threw my depth off. I had a lot of trouble trying to hold the piece for the end cut. I made a sled and used a backer board, but by the time I whittled through a 3 foot stick of wood, I decide to come see if anyone had an answer.
post #6 of 11 (permalink) Old 08-07-2014, 02:29 PM
I need to get my mind's eye focused...
are you routering vertically or horizontally???
what material thickness are you routering???
pick a bit/set from this link that is similar to yours....
Freud Tools
these are very good bits and come with videos....
who knows.. one of them just may be the answers you are looking for...
Freud Tools
are you having depth of cut issues???
are you having component (rail/stile) alignment issues???
post #7 of 11 (permalink) Old 08-07-2014, 02:32 PM
Welcome to the forum David. If you go to CMT's online catalog there is a description in it about how to set up the R & S bits along with a few other hard to adjust bits like the miter lock. I don't know if Rockler's jigs will work for your bits. It might only work for their own bits. You definitely need a sled or a good sized square push block for guiding the rails past the bit.
post #8 of 11 (permalink) Old 08-07-2014, 02:39 PM
sled.. very good move...
a miter w/ a hold down is a good move too...
cut your end grains 1st and then the edge grain... less wasteful..
you seem to be on your way...
when you get there make a set of set jigs and save them...
post #9 of 11 (permalink) Old 08-07-2014, 03:42 PM
First Name: del
i have a set and no problum with mine, i did a google search and go here and read you will get the answare you are looking for https://www.google.com/?gws_rd=ssl#q...and+style+bits
del schisler
port st. lucie, florida
del schisler is offline
post #10 of 11 (permalink) Old 08-07-2014, 06:35 PM
old55's Avatar
First Name: Ross
Ross,
old55 is offline
