Router Table - dedicated router - Router Forums
post #1 of 6 (permalink) Old 08-07-2014, 03:22 PM Thread Starter
Default Router Table - dedicated router
I just picked up a PC router table 696 (thick steel and aluminium top - made in USA). I have a Hatachi router combo and was considering gettting a dedictated router for the table rather than switching it out each time.
Do you guys use a dedicated router for your table set-up?
Mabye I could pick up a PC 690...?
Capitals is offline
post #2 of 6 (permalink) Old 08-07-2014, 05:01 PM
First Name: Clay
I do now, I added the 3 1/4 hp Triton. But I ran for years with just two routers and took it out and used it as needed.
fire65 is offline
post #3 of 6 (permalink) Old 08-07-2014, 05:56 PM
RainMan 2.0's Avatar
I used my pc690 in my table saw extension and had a few plunge routers . Going to build a separate router table with a PC7518.
You can't have to many routers or router tables in most of these guys opinions lol
Ok ,I never insulate
RainMan 2.0 is offline
post #4 of 6 (permalink) Old 08-07-2014, 08:41 PM
I had one that spent most of its time in the table. If you are going to dedicate one to a table I would go larger than a 690.
post #5 of 6 (permalink) Old 08-08-2014, 05:54 AM Thread Starter
Good info.
Thanks guys.
Capitals is offline
post #6 of 6 (permalink) Old 08-08-2014, 06:31 AM
kywoodchopper's Avatar
First Name: malcolm
Default router tables
It depends upon how often you would be needing to use the router in a table. Most of my routers are table mounted in dedicated tables with dedicated fences so it makes it faster to do a job.
Yesterday I needed to do round-overs on some pieces of wood, but didn't want to remove a router from a table. I had the router shown in the photos for several years, but seldom used it. I mounted it to the aluminum plate that came with the router then hung it on the side of the workbench. Since I was only making light cuts it would not be under any stress. It did the job. Instead of building another table I will probably just mount this router to a piece of plywood so it can be hung from the workbench for quick work. I will also add a dust port on the fence. It will be a dedicated router for just light round-overs. Malcolm / Kentucky USA
kywoodchopper is offline
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 15 01-26-2015 02:30 AM
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 01:51 AM
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 06:56 AM
