Router Tips and Techniques of the Day! - Router Forums
 7Likes
post #1 of 64 (permalink) Old 08-18-2014, 02:53 PM Thread Starter
Administrator
Cricket's Avatar
First Name: Cricket
Arrow Router Tips and Techniques of the Day!
What tips have you learned in your experience using a router that you wish you knew earlier?
What simple things do you do that save you time, effort, money, or just makes life easier for you?
Let's learn from each other and share our tips!
To keep this thread going come back each day to share a tip and read the latest posts.
jstammler likes this.
Cricket is offline
post #2 of 64 (permalink) Old 08-18-2014, 02:55 PM Thread Starter
Administrator
Cricket's Avatar
First Name: Cricket
Cricket is offline
post #3 of 64 (permalink) Old 08-18-2014, 03:05 PM
bearing guided bits as a 1st choice over router guide bushings when ever possible...
post #4 of 64 (permalink) Old 08-18-2014, 05:43 PM
Learning how to make jigs. There is no way to get from beginner to master without them.
rhamann2802 likes this.
post #5 of 64 (permalink) Old 08-18-2014, 10:10 PM
My tip for the 'back yard' wood worker would be to buy and learn the benefits of a set of guide bushings.
TWheels likes this.
Sydney, Australia
jw2170 is offline
post #6 of 64 (permalink) Old 08-19-2014, 07:27 AM
kywoodchopper's Avatar
First Name: malcolm
Default fence pivoting
With the router mounted in a table I make two different profiles on a box lid without changing the bit height. The bit I use is a classic ogee from Lee Valley. I set the fence approximately where it will need to be. On one end of the fence I drill a 3/8" hole through the fence support and through the table (home made fence and table). I insert a 3/8" bolt. This bolt is never removed. The other end I clamp the fence and adjust the fence until I get the deepest profile I'll want. This is generally a classic ogee cut. I drill a 3/8" hole through the fence at the end where the clamp is - hole through the fence support and tabletop. I then move the fence closer to the front of the table clamping it as I go until I get the 2nd profile. This profile is a slight round-over. I then drill another hole through the end of the fence support and tabletop where the clamp is. I put the two hole an inch or so apart. Now if I want to put a classic ogee cut on a box top I put a 3/8" bolt in the correct hole in the fence and on through the tabletop and make my cut. To make a round over on the bottom side of the box lid I pull the bolt out and move the fence toward the front of the table and put the 3/8" bolt into the other hole. Works perfect every time without changing the bit.
kywoodchopper is offline
post #7 of 64 (permalink) Old 08-19-2014, 07:36 AM
good idea...
box is very nicely done too...
post #8 of 64 (permalink) Old 08-19-2014, 12:29 PM
chessnut2's Avatar
Great idea, Malcolm. I have some of this work coming up, and I think you have saved me a lot of time and aggravation. Jim
chessnut2 is offline
post #9 of 64 (permalink) Old 08-19-2014, 02:15 PM Thread Starter
Administrator
Cricket's Avatar
First Name: Cricket
Cricket is offline
post #10 of 64 (permalink) Old 08-19-2014, 03:26 PM
Semipro's Avatar
First Name: John_*
Router tips for beginners
Routing - Some Beginners' Tips
Semipro is online now
Book, Shadow Box, how-to, tips & techniques knuttypine Project Plans and How To 1 03-04-2013 06:20 AM
Routing Tips and Techniques John Davitt New Member Introductions 1 08-13-2011 11:26 PM
No CD-ROM with Porter Cable 890 Router Combo Kit? Mort_Stevens Table-mounted Routing 11 08-29-2006 12:44 PM
Routing Tips and Techniques template tom Portable Routing 15 01-04-2006 02:52 AM
