Replacing the 7518 Porter Cable Speed Control - Router Forums
post #1 of 5 (permalink) Old 08-27-2014, 04:24 PM Thread Starter
First Name: Harold
Default Replacing the 7518 Porter Cable Speed Control
Has anyone replaced the speed control in their PC 7518 router? Mine appears bad (speed fluctuates significantly during routing) and I'm wondering if this have to go to a repair shop or is something I can do myself. The router is out of warranty and I am experienced in electrical repair.
Thanks much, Harold
Lanfearh is offline
post #2 of 5 (permalink) Old 08-27-2014, 04:31 PM
Thanks much, Harold
look to the brushes 1st...
bearings will make that happen too.. rare though...
if it is the speed control's that something you may be able to do...
but is it the armature...
Porter Cable 7518 Parts List and Diagram - Type 3 : eReplacementParts.com
post #3 of 5 (permalink) Old 08-27-2014, 05:08 PM Thread Starter
First Name: Harold
Thanks; I should have thought of that, but didn't. A likely source of the problem and easy/cheap fix. Harold
Lanfearh is offline
post #4 of 5 (permalink) Old 08-27-2014, 05:21 PM
hopefully...
post #5 of 5 (permalink) Old 08-28-2014, 06:15 AM
First Name: Dick
Howdy Harold and welcome. If you do determine it is the speed control you are probably better off looking for a remote speed control. Many people had rather have the control mounted to their table where it is easy to access. I can't recommend any controls, but I have seen several recommendations for the Harbor Freight unit, which is on sale now. The reviews are just as good as the Rockler unit, which cost almost 3 times as much.
Router Speed Control
Dick
Where there's a Willis there's a way!
Willway is offline
Porter Cable 5182 Versus 7518 Richard Carter General Routing 5 03-11-2019 11:47 AM
For Sale: Porter cable 7518 fixed base spopen Woodworking Classifieds 4 08-28-2012 01:03 PM
Porter Cable Router 7518 VS. 895PK ARCJR Table-mounted Routing 16 02-12-2012 06:11 PM
Remote PC 7518 speed control mntbighker Table-mounted Routing 5 01-02-2008 10:43 PM
Sold: Porter Cable 7518 for sale on Ebay... Breck724 Woodworking Classifieds 5 09-04-2007 06:15 PM
