The use of templates in the plunge cut - Router Forums
post #1 of 7 (permalink) Old 09-06-2014, 06:12 AM Thread Starter
tak35bne's Avatar
First Name: Dave
Default The use of templates in the plunge cut
The picture included with this post is just a stock pic to give you guys an idea about what I want to do. So.......what I want to do with my router is to make a cut in a piece of timber the exact size of the black base plate on the fly vise.
I would think that I would have to place the vise to be used for the template on a piece of MDF, trace it out and then cut that out so the base fits exactly in that MDF template. So what do I need to do with that templace in order to cut the timber out, only going down about 3 - 4 mm. Not sure what sort of bit to buy for this application and how to set the template up for the plunge cut.
Any help appreciated.
Dave
tak35bne is offline
post #2 of 7 (permalink) Old 09-06-2014, 08:57 AM
Honored Member
First Name: pat
You can box in the sample.
That is, clamp or screw down straight 4+" (say 1/4" MDF) wide stock around the work.
Put paper spacers (~.004" thick) between the sample and the MDF.
Pull the sample out of the surrounding mdf templets.
Move nothing, jig saw out the waste, the flush trim (rout) to the edges of the MDF.
Socket should be very close to your sample size.
If sloppy do it over again, this time with only one paper spacer for L&W, not all the way around.
Templates
Quillman is offline
post #3 of 7 (permalink) Old 09-06-2014, 05:32 PM Thread Starter
tak35bne's Avatar
First Name: Dave
Thanks Pat, but I think you are getting at making a hole in the sample. What I want to do is to rout out the material needed to insert the pedestal base of the vise into the sample just to keep it snug so it does not move around. Going down into the material about 5mm would be sufficient.
tak35bne is offline
post #4 of 7 (permalink) Old 09-06-2014, 06:05 PM
RainMan 2.0's Avatar
Once you built the template around the perimeter you could plunge down as far as necessary .
My concern is the corners , as they are a right angle and the bit is going to have a quarter inch radius
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 7 (permalink) Old 09-06-2014, 06:11 PM
Assuming the objective to hold this vise temporarily in place , I think I'd be tempted to build a piece underneath it that would connect to the wooden platform . If the platform had a matching slot that the base would slide into sort of thing
post #6 of 7 (permalink) Old 09-07-2014, 01:32 PM
First Name: Dick
Hi Dave. Watch this video, I think it would do exactly what you want to do, althought that is not what it is designed for.. I don't know what bits you have available down there but the are being made by many companies.
https://www.youtube.com/watch?v=HER0GeyG5cU
Dick
Where there's a Willis there's a way!
Willway is offline
post #7 of 7 (permalink) Old 09-08-2014, 03:09 AM Thread Starter
tak35bne's Avatar
First Name: Dave
thanks for that info. Just found that item at an Australian supplier and should be here in a few days............
tak35bne is offline
Setting depth of cut accurately greyguru New Member Introductions 12 09-15-2014 03:47 PM
Suggests to set the router for a plunge cut tak35bne General Routing 14 09-04-2014 06:11 PM
Question about plunge base on Ridgid router Sawatzky General Routing 12 01-01-2011 11:44 PM
Freud 2200E -- How do I set it up for a measured depth plunge cut? Ladd General Routing 8 11-12-2007 03:23 PM
Up Cut... Down Cut... Joe Lyddon Router Bits - Types and Usage 2 09-10-2006 06:21 PM
