Foam Shadow boxes - Router Forums
post #1 of 6 (permalink) Old 09-09-2014, 04:23 PM Thread Starter
First Name: Chris
Default Foam Shadow boxes
I am new to CNC machining, and my company has asked me to learn speed and feed rates to cut foam Shadow boxes. the foam being used is called 4# crosslink, it is a polyethylene foam plank. I have done some testing on this foam, with double flute up cut bits, for pockets and have gotten fair smoothness on the walls. the end user wants better like always. I have increased RPM and lowered feed rate, but the bits are breaking. Then I have tried slower RPM and lower feed rate as well with no luck. So I am thinking it might be the BIT I am using. Has anybody cut this foam and will be willing to share some information on bits, rpm speed, and feed rate that has worked for them, before I go and spend another $300 on the same bits.
Chris
afpchrisd is offline
post #2 of 6 (permalink) Old 09-09-2014, 04:41 PM
Chris
what bit are you using???
post #3 of 6 (permalink) Old 09-09-2014, 04:55 PM Thread Starter
First Name: Chris
I am currently using Amana solid Carbide Spiral Foam up cut bits, ranging from 1/8"- 3/8" dia. depending on how much material is needing to be removed
post #4 of 6 (permalink) Old 09-09-2014, 05:34 PM
believe it or not... try these bits.....
each one is a tad different... lots to pick from...
the saber cut... underlayment... laminate..
Cut-Off Wheels
post #5 of 6 (permalink) Old 09-10-2014, 08:35 AM
First Name: Richard
Send a message via Skype™ to rwbaker
What you are doing is closer to production light metal CNC machining. Try a end mill house like W T TOOL to find inexpensive bits to play with. You might also want to vist Practical Machinist - Largest Manufacturing Technology Forum on the Web - this is a production/industrial group similar to Router forums but dedicated to your type of problem - these guys are CNC pros and use the tool 24/7.
Baker - do not go through alone unless your question is really stupid- good luck
rwbaker is offline
post #6 of 6 (permalink) Old 09-26-2014, 07:28 AM
First Name: Chuck
You are breaking bits?
Patriotworks is offline
Routing rigid foam? bobbotron General Routing 12 01-17-2013 06:56 PM
Turning foam on a lathe? Bulldogg629 Woodturning and Lathes 9 07-01-2012 02:16 AM
Latest batch of boxes... TwoSkies57 TwoSkies57 Gallery 34 04-20-2012 10:57 AM
Boxes, Trivets and Stools xplorx4 Show N' Tell 5 10-26-2011 03:49 AM
Sourcing wood for small boxes tomcoleman Starting Off 2 11-19-2008 10:32 PM
