Bits for Ryobi Router - Router Forums
post #1 of 8 (permalink) Old 09-10-2014, 09:36 AM Thread Starter
Country: Portugal
First Name: Rui
Default Bits for Ryobi Router
I own a Ryobi Router (handheld no table) and I wonder which bits you would recommend? Which kind of bits are approriate for a beginner? Thanks
Rui Lobo
post #2 of 8 (permalink) Old 09-10-2014, 01:17 PM
First Name: Phil
Rui, welcome to the forum. I think most folks would say the bits you need will depend on what you want to do with your router and what size shank it will accept.
Phil
Phil Dalton is offline
post #3 of 8 (permalink) Old 09-10-2014, 01:47 PM
As Phil pointed out Rui the size shaft on your bits will depend on your router. In North America many Ryobi routers only accept 1/4" shaft bits (about 6.35mm) but I can't say for sure that is what you have there. Your instruction manual should say. The most common bits that are used are round overs between 3/16 and 3/8 radius, straight bits for cutting grooves and recesses, roman ogee bits for edge treatments are popular, and maybe a cove bit or two in the same sizes as the round overs. If you want to make signs then a v point bit or a sign making bit (v with the tip cut off) would be needed.Those bits would get you started.
post #4 of 8 (permalink) Old 09-11-2014, 05:56 AM
First Name: Richard
Send a message via Skype™ to rwbaker
The work you do will decide the bit patterns. I know an individual that does not have a single straight bit yet almost everyone else has multiple bits. Buy what you need when you need it.
Good Luck - Baker
rwbaker is offline
post #5 of 8 (permalink) Old 09-11-2014, 11:55 AM
MAFoElffen's Avatar
Rui Lobo
Just a suggestion- Since starting out, buy a combo starter set, like the Ryobi 15 piece (A25RS15) or the Bosch 12 piece (91912)... or similar. There are similar low-cost sets of varied quality. Treat then as a test batch for your learning.
Usually buying bits separately for quality bit will run you around 20+ each. With a starter set like that, you can get started practicing making profiles and learning how to use your router.
As you wear out "a bit," those are bits you use, in what you do. Replace it with a higher quality bit.
MAFoElffen is offline
post #6 of 8 (permalink) Old 09-15-2014, 05:07 AM Thread Starter
Country: Portugal
First Name: Rui
My Router has both the 6 and 8 mm adapters. Does that help?
post #7 of 8 (permalink) Old 09-15-2014, 05:10 AM Thread Starter
Country: Portugal
First Name: Rui
[QUOTE=MAFoElffen;398139]Just a suggestion- Since starting out, buy a combo starter set, like the Ryobi 15 piece (A25RS15) or the Bosch 12 piece (91912)... or similar. There are similar low-cost sets of varied quality. Treat then as a test batch for your learning.
I did think of that but for some strrange reason the sets are catalogued but not avaulable for sale anywhere I could find.
post #8 of 8 (permalink) Old 09-15-2014, 09:16 AM
If your router only takes those sizes you will have to be careful that the shanks are the right size for your router. In North America our shanks are 1/4" and 1/2" as the norm.
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Replacement Router Bits for the Craftsman Router Crafter Brian in Burlington Router Bits - Types and Usage 1 11-17-2009 11:33 AM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
