Large quarter round? - Router Forums
post #1 of 14 (permalink) Old 09-11-2014, 01:07 PM Thread Starter
Default Large quarter round?
Hello! I am new to routers, don't even have one, but am exploring the idea of making my own quarter round. I have an old house, and I have removed the carper to refinish the wood underneath. In one room, there are boards that are up to 1 3/4 from the wall. I wanted to get some 1 3/4 inch quarter round. This doesn't seem to exist. I called a millwork place, and they want $300+ to get me 1 3/4 quarter round (2.99/ft + 150 setup) and 7-10 business days. I figured I could get some 2x2's and round them out and call it a day. How would I go about doing this?
cokewithvanilla is offline
post #2 of 14 (permalink) Old 09-11-2014, 01:30 PM
You can't with a router. The largest 1/4 round is 1.5" radius for a router. Any larger is too large a diameter. 1.75 would be 1.75 x 2 plus the diameter of the bearing which would be minimum .5" which would put you art 4" diameter.I have a 1.5 inch and it just fits the opening in the base of my router, a big 3.5 hp plunge.
I would also suggest that a 1.75" quarter round is going to look totally off balanced and I don't think you will be happy with the results. I would figure out a practical way of filling the gap and then use baseboard possibly with a small quarter round added on if needed.
post #3 of 14 (permalink) Old 09-11-2014, 02:12 PM Thread Starter
Thanks for the reply.
The house is 1935, so the baseboard is like 10 inches, with a quarter round cap. It looks like it originally had some giant quarter round at the bottom (from the line on the wood). The molding also has 2 pieces running through it... i can't really stack boards
post #4 of 14 (permalink) Old 09-11-2014, 03:42 PM
good chance you had shoe molding at the base....
quarter round that large was probably cut on a shaper...
or it wasn't true quarter round but thumbnail..
Molding & Edging :: Edging :: X-Large Thumbnail Table Edge Router Bit - 1/2" Shank - Yonico 13143
how many lineal feet of molding do you need???
do you have a table saw???
spoke shave???
Lee Valley Tools - Veritas® Concave Spokeshave
BTW... IRL a 2x2 is 1.5 inches square on a good day...
Stick486 is offline
post #5 of 14 (permalink) Old 09-11-2014, 06:43 PM
First Name: Clay
Welcome to the forum. Some pics of what you are dealing would help.
fire65 is offline
post #6 of 14 (permalink) Old 09-12-2014, 05:40 AM
First Name: Andy
Yes a 1.75" radius quarter round sounds huge, it would really draw the eye I think. If it's necessary to cover a gap that large I'd go for a something with a flatter profile, like a 1x2 laid flat with a 3/4" radius on the edge.
I wonder if there's such a thing as a "one-eighth round" router bit? So you could make a large quarter-round with two passes, without the bit needing to have such a large diameter?
AndyL is offline
post #7 of 14 (permalink) Old 09-12-2014, 11:38 AM Thread Starter
Problem is, the wall already has a baseboard that has accents and whatnot. Adding 2 additional pieces may attract more attention than the large bullnose. Who knows. I am selling the house. I've even considered putting 1 3/4 inch crown molding down. I just need it done.
Ill send pics as soon as I can,... it doesn't let me attach pictures in the normal way cause of post count.
post #8 of 14 (permalink) Old 09-12-2014, 11:43 AM
Forum Moderator
Semipro's Avatar
First Name: John_*
You are allowed pictures as long as they are on your computer hardrive.
Semipro is online now
post #9 of 14 (permalink) Old 09-12-2014, 11:53 AM
First Name: Andy
I wasn't suggesting adding 2 pieces, just a 1x2 with a rounded-over edge. The same as your original idea of a rounded-over 2x2, but lower in profile, and easy to make with a normal router.
AndyL is offline
post #10 of 14 (permalink) Old 09-12-2014, 01:33 PM
Bushwhacker's Avatar
First Name: David
Default giant 1/4 round
Could the missing trim have been possibly inside cornor mold.
When the enemy is with in range, so are you....
When the enemy is in range, so are you.
Bushwhacker is offline
Round over bit. On 1.5mm & 3mm Wood. Possible? mouchmouch Router Bits - Types and Usage 3 05-06-2013 10:32 AM
Sign Making: Round Nose Bits newmexico Sign Creation 3 08-16-2012 04:02 PM
3/4 inch pine, what roundover bit? Karter Router Bits - Types and Usage 9 02-21-2011 04:57 PM
new to forum/ quarter round query sway1963 New Member Introductions 3 02-02-2010 11:47 PM
Looking to commission woodworker for round end table Hockeystyx Tools and Woodworking 1 10-26-2009 10:14 AM
