Porter Cable 690 Troubleshooting Advice - Router Forums
post #1 of 15 (permalink) Old 09-12-2014, 05:21 PM Thread Starter
First Name: Lynn
Default Porter Cable 690 Troubleshooting Advice
I picked up a free PC-690 variable speed with a plunge base and no other accessories or manual. I brought it home and fired it up. It ran ok on low speed then turned it off and fired it back up and then switched to high speed. It ran a few second and slowed then stopped. While it was running I noticed a small amount of blue sparks comng from the top just before it quit. I have seen motors do this a little but this was a little more than normal. I don't think it had been used in quite awhile. Just curious where I should start looking before thinking of sinking money into parts.
Lynn1953 is offline
post #2 of 15 (permalink) Old 09-12-2014, 05:34 PM
look to the brushes...
believe you need a cleaning also...
post #3 of 15 (permalink) Old 09-12-2014, 05:40 PM Thread Starter
First Name: Lynn
I took one brush out. Im not sure I can tell if it is good or bad. but the router looked well used and a little grimey.
Lynn1953 is offline
post #4 of 15 (permalink) Old 09-12-2014, 06:16 PM
take the brushes out and clean the commutator ...
how long are the brushes???
post #5 of 15 (permalink) Old 09-12-2014, 06:24 PM
First Name: Clay
Agree, tear it down and clean it and put two new brushes in it. The 690 is a great router.
fire65 is offline
post #6 of 15 (permalink) Old 09-12-2014, 06:46 PM
Al B Thayer's Avatar
First Name: Al
Default 2 speeds?
I have 4 690s. None of them have more than one speed. Is this a old model or a very new model?
I have replaced the bearings before. Its not too hard to do. If you hear a squeak when you spin it by hand. Your about due. $20 for the bearings on ebay.
Al
Al B Thayer is offline
post #7 of 15 (permalink) Old 09-12-2014, 07:18 PM
Power Tool Parts | Great Selection | Great Prices | eReplacementParts.com
post #8 of 15 (permalink) Old 09-12-2014, 08:44 PM Thread Starter
First Name: Lynn
I'll check the length and get back and it has 4 speeds.
Lynn1953 is offline
post #9 of 15 (permalink) Old 09-12-2014, 09:34 PM
RainMan 2.0's Avatar
Al
That was my question , as I have a PC690 and it's either off or on
Ok ,I never insulate
RainMan 2.0 is online now
post #10 of 15 (permalink) Old 09-12-2014, 11:34 PM
Al
it's probably 690LRVS in plunge base making it a 694VK....
Porter Cable 690 plunge Router pawneehawk1 General Routing 1 06-16-2011 09:18 PM
Porter Cable 690 questions daveb89 Portable Routing 4 01-28-2011 08:15 PM
Bosch 1617vs Verses 690 Porter cable Glenmore Tool Reviews 20 08-09-2009 09:36 PM
Porter Cable 690 PeterLowes General Routing 3 01-20-2009 12:57 PM
Porter Cable 690 D handle router S Bolton General Routing 17 09-22-2007 10:28 PM
